Page 7 of 9
Posted: 29 Jun 2020, 17:40
Its been a couple of weeks since I was able to show any progress on the B4. In the background I have wet & dry sanded the fuselage and the wings following the glass cloth and epoxy session.
I have also fitted the canopy glazing to the frame and painted it up. It is just as well that I ordered 2 canopy mouldings as I made a right pigs ear of fitting the first attempt! The trimming and fitting process went ok and it all looked good. However I used “canopy glue” to attach the glazing to the frame before taping it down securely – I THOUGHT! When I undid all the tape it was a right mess. Bits of the glazing were coming away from the frame, some sections had pulled squint and I ended up ripping it all off.
I decided to use good old Evostik contact glue for the next attempt and it worked just fine.
I have a bit of cockpit detail still to do but I can see “PAINTING” approaching quite soon and I’m not looking forward to that.
By the way the more observant of you may have noticed that I have installed a new worktop to my workbench. I had to use Plywood as I couldn’t get hold of 18mm chipboard anywhere. Is chipboard the new toilet paper?
Posted: 29 Jun 2020, 19:16
Posted: 29 Jun 2020, 21:38
Life is rough Barry!
Posted: 25 Jul 2020, 19:17
I see that my last post was at the end of June so I am due an update. Plenty has happened with the build since then but not a lot of progress. I shall explain!
The wings and fuselage were covered with glass cloth and epoxy and all sanded back with 120 and 240 wet and dry. I was very happy with the finish as it was nice and smooth with very few blemishes. I applied a coat of white primer to everything and that’s when things started going wrong. The primer showed that although the surfaces felt smooth in fact the cloth weave was showing through. In addition there were masses of pin holes in the finish. Stupidly I applied a second coat of white primer and that didn’t improve matters one small bit. At this point I suspect that if Chris Williams is reading this he will be shaking his head and having a chuckle.
I bit the bullet, got out more 240 wet and dry and started rubbing down once again. When all the primer was gone I re-coated the whole airframe with another thin coat of epoxy followed by more rubbing back. This time when I resprayed the airframe with white primer there was no weave showing at all but there was still a lot of pin holes – out with the filler! There then followed several days of fill followed by sand back and gradually the number of pinholes was reduced. Finally I applied a further coat of primer followed by three coats of white gloss. By this time my right bicep was bulging and my shoulder aching.
In the last week or so I have got the ailerons fitted and servos installed. The elevator servo installed and a small moulded hatch created to cover the hole in the fin. It had to have a moulded bulge to clear the servo arm. The rudder was added and the servo installed in the fuselage. I have also created in interior for the cockpit including a natty little seat. This afternoon I have inserted the sockets for the wing retaining system and also the hinges for the undercarriage doors.
All photos below!
Posted: 25 Jul 2020, 20:15
Very clever fish in your part off the world Brian
Posted: 25 Jul 2020, 21:23
(chuckle, chuckle)
Posted: 31 Jul 2020, 12:20
My Pilatus B4 build is now complete!!!
I have been working away quite steadily for the last few days on the installation of the undercarriage, the aerotow release and radio gear.
This morning I was able to assemble the model and check that everything waggles correctly and in the correct direction. The CG positions were recalculated and the model mounted on the balancer. I say positions (plural) as I always start with a “safe” slightly forward CG position for the first flights and then gradually move the CG rearwards until I get the aeroplane handling the way I want. I calculated the forward CG position using a static margin of 15% and a rearward CG position using a static margin of 10%. This placed the two CG locations 12mm apart on the wing root. A total of 473gm in the nose was required to achieve the forward CG position. However 130gm of lead can be removed incrementally to move the CG back to suit my flying taste. The total weight of the model came out at 5.20 kg – 11 lbs 6oz in old money.
I am rather pleased with the finished model and now only require a suitable day for the maiden flight.
Posted: 31 Jul 2020, 12:27
Posted: 31 Jul 2020, 15:52
Looks very nice Brian - the model that is
Posted: 31 Jul 2020, 17:17
by terry white
Looks superb Brian, Should fly well. Thanks for a brilliant build thread, very informative and entertaining.
