just had the first flight with my winter project , HF Models ASW 28 with a Wren 44 turbine .
I got the model for a very good price and required lots of tlc including finding and fitting a new canopy new servos some structural work to the wings and a fresh coat of paint .
Looking forward to some better weather for further test flights.
HF Models ASw 28 turbine
- Attachments
- 83312694_2854103214910503_636295668280852480_n.jpg (11.12 KiB) Viewed 1033 times
- 85065202_2864119053908919_4721763779661004800_n.jpg (13.68 KiB) Viewed 1026 times
- 83224199_2854103368243821_7405527429470486528_n.jpg (7.89 KiB) Viewed 1026 times
- 84189853_2859652147688943_9175523644456042496_n.jpg (10.17 KiB) Viewed 1025 times
Re: HF Models ASw 28 turbine
that lookes a good conversion, enjoy , i will try to send some good weather if I can find a box big enough!
Geoff,
thanks I enjoyed re building it , the canopy was a challenge as it arrived 4 cm too short so I spent ages building a new frame from glass and balsa , carbon tows etc .The other issue was fitting a fuel tank as its got a retract that happens to be in the way of the perfect tank location , I ended up making my own conformal tank that sits just about on the c of g and enabled a full depth cockpit .
best thing its cheaper than a fancy EDF and more fun than waiting for a tug to show up ???
