Page 5 of 10
Re: ZUGVOGEL IIIa 1/4.2 SCALE
Posted: 15 Apr 2020, 09:35
When it comes to the wing root fairing, I like to make up a stiff framework to ensure a snug fit between the wings... Obviously, this is best done with the wing rigged.
Posted: 16 Apr 2020, 11:49
With the fairing frame shaped to the contour of the wings, the three 8mm magnets can now be set up between the fairing frame and the rear of the canopy frame...
Posted: 17 Apr 2020, 09:44
Well, would you Adam & Eve it...the Skylark 4 canopy comes up trumps again
Posted: 18 Apr 2020, 10:03
The wing fairing now needs to be itself faired in to the rear of the cockpit and the top of the fuselage at the TE. At the rear it need a definite line to match the top stringer on top of the fuselage. One way to do this is to do in two stages: first masking out one side to form a straight line and filling up to it, before removing the masking tape; then filling the other side up to the line before final sanding...
Posted: 19 Apr 2020, 09:38
The ailerons have been built via the Williams No 2 method, i.e. directly in the wing...
Posted: 19 Apr 2020, 11:03
by Ray Watts
Ah what a shame Chris. I thought maybe you'd get this one done in one month, but I don't think that even at your building speed, you're going to finish this in the next 2 days.
Yes, Challenge posted.
Posted: 20 Apr 2020, 10:00
No prob, Ray...here you go.
Posted: 20 Apr 2020, 10:03
All right Fake News, but I can produce the completed airframe within the challenge, though...
Meanwhile, 6 bottles of Valium on standby, it's time to do the airbrakes...
Posted: 21 Apr 2020, 09:52
It would seem that there is a strict sequence in which the holes are drilled that will produce a bind-free system. I won't go into detail, as this looks like a good subject for a later Lockdown Article...
Posted: 21 Apr 2020, 11:29
by WayneB
I will look forward to this article. Top job.
