Scheibe Spatz
StephenB
Scheibe Spatz
Post by StephenB »
The model as designed by Chris Williams as an A-Spatz or, as Chris describes it, a "Spatz 1" is at a scale of 1:3.5 giving a wingspan of 3.8 metres. Early examples built by Scheibe were designated A or B, followed by the later L version, it's difficult to find online sources for verification of the differences, most A types seem to be without a wheel, some have shoulder mounted wings, some top mounted and canopies seem to vary too. So, not easy to find a full size to accurately model, mine will probably end up as this:
To speed the build process I ordered the laser cut short kit and plan from Cliff at Laser Cut Sailplanes, the parts all neatly packaged and bagged according to their use - left wing ribs in one bag, right wing ribs in another and so on. Balsa sheet and strip, spruce strip and ply were sourced along with the electronics, covering material and various hardware to produce a complete kit of parts:
The Bridson jig was deployed and the laser cut former supports were glued to the adjustable angle pieces with CA before sliding in to position and checking for correct alignment referenced against the dimensions marked on the plan:
The 1.5mm ply keel was strengthened by adding 1.5mm ply doublers in the wheel box area before glueing both sides on to formers 2, 3 and 4 with aliphatic. This assembly was then dropped on to the jig where the 6mm square spruce longerons could be added:
Dale Nicholls
Re: Scheibe Spatz
Post by Dale Nicholls »
StephenB,
Here is some inspiration for you. The model turns out very nice and is a great size.
The overall handling is very benign, enjoyable to fly.
If you have any questions or queries please reach out.
Dale Nicholls
StephenB
Re: Scheibe Spatz
Post by StephenB »
Hello Dale, nice job!
Did you build from the plan or the laser cut kit? Any challenges in the build that you had to overcome?
Dale Nicholls
Re: Scheibe Spatz
Hi there Stephen,
my model was handcuff off the plans, so no laser cut parts involved.
I followed the plans in all respects and its a well conceived design as you would expect from Mr. Williams.
The only suggestion I would make is to update the elevator connection to a ball link fitting (as per his later designs) to make it easier to detach and attach the stab. The model flies very well and is an easy flyer.
I have many photos during the build so if you have a question please ask.
enjoy the build.
Dale
StephenB
Re: Scheibe Spatz
Post by StephenB »
The spruce longerons were bonder in place with the main one requiring some steam bending around the cockpit area, a removable cockpit floor was fabricated from liteply to allow access to cabling and the tow release servo:
I then set about adding the ply plates that form the wing box area, here I encountered a problem - the top plate H2 was a little undersize so required some fettling:
I then discovered that F4 didn't have the hole cut to accept the bottom longeron and F8 was not opened out at all, so nowhere for the pushrod to go! Of course I didn't spot these issues until after I had bonded them, in but F4 was easily dealt with in situ with the Dremel and F8 was carefully removed and opened out on the scroll saw. Onward and upward after this, 6mm square balsa cross bracing added and the ply sheeting glued on to the top decking:
Tow release servo added, this will connect via a Bowden out to a Multiplex aero coupling:
To get as much weight as far forward as possible a battery box was fabricated from birch ply to take the 4200mAh NiMH, this was epoxied in place and additionally secured with screws which will also give the car body filler something to key to when forming the nose:
A ply plate with captive nut for the tailplane retention was glued in place, a "paddle" to operate the elevator was fabricated from piano wire and brass:
With rudder, elevator and tow release servos in place the next job will be to sheet the forward fuselage.
john greenfield
Re: Scheibe Spatz
Post by john greenfield »
That looks like a very small and weak servo for a tow release, especially a Multiplex type with a retracting pin. When everything goes wrong on the tow you need a super reliable release system that will work under any load. As you have the space, may I suggest you fit a much more powerful servo.
StephenB
Re: Scheibe Spatz
Post by StephenB »
How much torque would be right for the release John?
I have no experience of these but Multiplex describe the aero tow mechanism thus: "To operate the release all you need is a low-cost standard servo and
a length of 1.2 mm Ø steel rod running in a snake outer sleeve.
Re: Scheibe Spatz
In my experience over a range of models, the MPX release works very well with a standard servo for models up to 22lbs. The advantage of this system over cam-in-a-tube variety is that very little movement is required to release, so the rod can be set in the innermost hole of the servo arm for max torque...
patte de loup
Re: Scheibe Spatz
Post by patte de loup »
For testing the tow system , including the servo , you should be able to release by pulling the tow cable with a force equal to the weight of your glider. That's the rule, we apply for our GPR glider ( over 5 meters wingspan ) during the meeting.
Pat'
john greenfield
Re: Scheibe Spatz
Stephen
I agree with all of the above. Min movement on the pin to get max torque from the servo and test the release to ensure it works (every time) with a pull at least equal to the weight of the glider.
