Motor Falke ¼ scale - Cliff Charlesworth.
Max Wright
Post by Max Wright »
There is a lot of waiting associated with this sport.
lasercutsailplanes.co.uk were very quick getting the plans and short kit to me.
. . . but I'm still waiting for my magnets from airfieldmodels.com
https://airfieldmodels.com/store/magnet ... sories.htm
As this is really my first "proper" build, I may be leaning on you all to get me through.
What have I received is my magnetic building board and I've build a Robbie Bridson fuse building jig . . .
and my Cliff Charlesworth "Model Gliders" book from sarikhobbies.com
We were worried that it had become lost, so Barry sent me a replacement. When it arrives, I'll return it.
T-61A 2.JPG (10.93 KiB) Viewed 407 times
Max
Max Wright
Re: Motor Falke ¼ scale - Cliff Charlesworth.
In the meantime, I've read the tribute thread for Cliff Charlesworth, and I've read his book several times.
When the magnets arrive, I thought that I would start with the rear stabiliser.
It seems to be the logical place.
Max
Max Wright
I've already had some excellent advice from Trevor - as well as links to his build.
With Trevor's permission, I want to post the links here so I can keep going back to refer to them.
http://www.bartonhewsons.uk/home/modelf ... ydata.html
https://www.rcgroups.com/forums/showthr ... tor-Glider
Thanks, Trevor.
The most interesting (and terrifying), aspect I've found so far is the unusual box spar for the wings. It will certainly be an achievement if I can pull that one off.
I'd better get my big boy's pants on. :lol:
Max
Max,
The box spar method was often used by Cliff Charlesworth in his designs.
I normally build onto the lower spar, but if you can cut the ribs accurately/line up LE & TEs then the box spar method also works.
I know several builders who also like Cliff’s method.
Max Wright
Thanks, Peter
I appreciate your remarks.
Max
Max Wright
OK. I've had a few days to read Trevor's thread over and over. Thank goodness for it - or I would be stonkered. :shock:
Reckon that I'll have a crack at the wing. I'll order a sheet of 3mm spruce for the spar; but I will need a Graupner 15mm wing joiner tube.
It looks like it's rectangular (or oblong) in the photos - made of brass.
And that tells me that the wing joiner is flat - maybe steel or aluminium?
Does anyone have an idea where I could obtain these bits?
Max
Max,
The wing joiner system on most of Cliff’s designs (and many others) comprises a flat carbon steel (steel is somewhat similar to piano wire) strip in a 0.5mm wall thickness brass box.
The original designs probably used a 14x2mm steel strip in a 15x3mm O.D. brass box.
However, owing to problems in getting reliably fitting materials a few years ago, this arrangement has been superseded by a 15x2mm strip in a 16x3mm brass box.
In the U.K. the strip/brass box combinations can be found in 1m lengths at Gliders Distribution, but I don’t know if you have an equivalent source own under.
Max Wright
Thanks, Peter.
I wish I'd known about Gliders Distribution when I started restoring my A-14. It had a strip and box system, but I wasn't able to find anything like that in Oz. I ended up using a 15mm carbon fibre rod in a plastic conduit tube. :?
Anyway, I'll Google GD and get a set underway.
The plans are dated 1988, so I guess things have moved on a bit.
I appreciate your help.
Max
Max Wright
They're called gliders.uk.com now.
It's out of stock at the minute, but I've paid for a set and it's gone to back order.
So I'll start sourcing the timber - and continue working on my A-14, as well.
This was never going to be a quick build. :lol:
Max
Max Wright
So, I'm still in limbo land, waiting for stuff . . .
The building magnet devices were ordered and paid for on the 18th of August . . .
The steel blade and brass box were back ordered (and paid for), on 10th September . . .
I'm going to the city tomorrow for work. I'll see if I can get the timber for the box spar.
Max
