Motor Falke ¼ scale - Cliff Charlesworth.
Re: Motor Falke ¼ scale - Cliff Charlesworth.
Max,
No, if you look at the first wing build post (28 Nov?), you will see that I used my normal build method - build wing up from lower main spar, notching each rib onto the spar.
If the ribs didn’t have notches as laser cut then I would have cut them by hand.
The build log post says that I built the ribs onto the bottom spar, raising the outer TE by 5mm? as required for the washout.
The photo shows the intact rib section between the spars to confirm the above.
The Cliff Charlesworth method of build was to make up a spar box & then slice out this section of each full rib to suit - meaning that the cut angles had to be different, but correct in order to avoid a wavy TE.
However, it is easy enough to mark the spar position on each rib from the plan & then notch each rib top & bottom. I can’t recall if the spars taper, but this can be worked out & taken into account in the notching.
The ribs can then be placed with TE at the correct level along the span to get straight TE lines.
Max Wright
Post by Max Wright »
I'm confusing myself by reading Trevor's build log and your thread on the SF-33.
They are two different aircraft, but I took it that the spar design was common.
This is a shot from 18th March, 2015 . . .
Wing root.jpg (6.42 KiB) Viewed 125 times
It looks like you've left filling in the spaces in the vertical sides of the spar until later.
Max
Max,
Yes. If you notch the ribs to sit the ribs onto the bottom spar and drop in the top spar, you need to complete the box by adding vertical grain spar webs between each rib.
Photo of spoiler area posted on 12th Jan 2019 shows the spar webs in that area.
To get the full box spar equivalent you add webs front& back, but the benefit is that:
a) the webs don’t necessarily need to fill 100% of the inter-rib gap;
b) the webs can more easily be vertical grain - stronger than horizontal grain.
c) you can more easily get at front & rear of the assembled joiner area to block this in - solidly bonding joiner to spars.
The whole point of the box section is to tie the two spars together to make the spar system resistant to higher bending loads - however that is achieved. Note that many wing designs use just a front or rear web to achieve a similar objective, saving weight but not quite as strong.
Max Wright
Ah. Thanks, Peter.
I guess a spar is like a truss; in that in a truss, the vertical sides actually have spaces - or is some cases the vertical is just a rod bent into a row of z'ds.
What occurs to me is, that if there are spaces the spar could become the conduit for the wing servos.
Max
Max Wright wrote:
13 Oct 2020, 00:27
Max, if you mean using the spar box for servo cable routing - then yes no problem, although the root section should be fairly solid around the joiner so just exit the box just before you get there.
Max Wright
Sorry, Pete.
I should use the Smilies. :oops:
Not everyone gets my humour.
Thanks for your interest.
Max
Seemed like a sensible idea to me...
8-) 8-) 8-) 8-)
Max Wright
Many a true word . . .
I'm starting to like it, Baz. ;)
Max
