Motor Falke ¼ scale - Cliff Charlesworth.
Max Wright
Re: Motor Falke ¼ scale - Cliff Charlesworth.
Post by Max Wright »
Thanks for the Drop box, Cliff.
My PM's are are still hanging up in the Outbox, so you're not getting them, Cliff.
I've dragged and dropped the photos into the box.
Is there a Send button somewhere?
Max
Max
Pm's stay in your outbox until they are picked up by the recipient!
Laser Cut sailplanes
Max Wright
Ah. Thanks.
Every forum has it's idiosyncrasies. :D
Max
I would have said that, but I could not spell it.....
Max Wright
OK. So the drawing of what I took to be a wing elevation, turned out to be the profile of the wing spar. :oops:
Now I have begun to lay out all of the parts so I can make sure that I get the wing joiner right.
I appear to be short number 1 rib.
The fuselage instructions seem to be saying that I have to make that rib myzelf.
The ribs I have appear to mount on to the fuselage as they have slots for tabs on the frames.
So, do I have to cut another number 1 rib (leaving out the tab slots)?
Or have I taken myself up the garden path again?
Max
Max, Rib 1 is that same as the root rib, I can send them to you but it would be quicker for you to use the root rib as a template and cut the yourself. It is strange that it is not there as it is cut from the same sheet as the rest of the 3mm ply!
Max Wright
Thanks, Cliff.
I've tipped all of the bags out, but no joy.
I have a friend with a cutter. Shouldn't be a problem.
Max
Max/Cliff,
I would have thought that the wing root ribs don’t have the fuselage slots as Max says, but also doesn’t have the wing retainer clearance apertures - otherwise you have no rib material to mount the retainers into ;)
What I should have said Peter is that the outline of the root rib is the same as rib 1, just cut the outline! Max, you should be able to draw around the rib and use a bandsaw.
Max Wright
You're right, Peter.
The apertures are solid in wing rib 1, but I want to make sure that the wing joiner slots are cut as accurately as possible.
Max
