Peter,
Good to hear that. I feel the same what you mentioned in the last paragraph. It once saved a plane when the connector with the main battery failed.
Best regards, Vincent
Scratch built Slingsby King Kite 1/4
- Bovin
- Bovin
Now I could cover the bottom of the fuselage. I came up with a sanding tool so I could clamp the panels, otherwise my fingers would get cramped
Vincent
A batten attached to my worktop with a screw clamp , a piece of aluminum angle and two large spring clamps. The sanding went a bit better now. . Fuselage and panel with glue , panel in position and secured with a hot iron. wetted with a sponge bent and secured. After a few days it starts to become a fuselage . Next is the nose, lots of panels ...Vincent
