MINIMOA 1/4 SCALE
Adam C
Re: MINIMOA 1/4 SCALE
Post by Adam C »
Watching, learning and enjoying.
With the interior of the fuselage cleared out, F5a can be installed and the top sheeting applied. A card template is useful for determining the rough shape of the top decking, which is wetted up, taped into a curve, and ironed dry before fitting. I used 0.8mm ply on the prototype, but these days I would now recommend 0.6mm ply...
Before the rear of the fuselage can be finalised, the tailplane must be put together. The basic frame has the top sheeting added first (because the tailplane tapers in thickness underneath); then the jig supports are spot-glued to it and the tailplane put inverted on the board whilst the bottom sheeting is applied. Both top and bottom sheeting overlap the rear spar to from a shroud for the elevator. The elevator's false LE is offered up at this stage to synchronise the holes for the Robart style hinges...
Once the elevator false LE is hinged up, the TE & ribs can be added. Once complete, the elevator is sanded flush to the tailplane.
Now it's time for the elevator actuation arrangement: Hopefully, the pics should be self-explanatory. Because the servos are difficult to access, they are mounted on a removable plate should any maintenance be required.
Now the rear end of the fuselage can be closed up. Note the rudder cable guides that will be embedded inside the ply outer covering...
Time now to put the rudder together: as I don't seem to have any pics of the process, I've used the ones from the 5th scale build, which, apart from the size, is pretty much identical...
On the full-size, the gap between the rudder and the fuselage was covered by hinged plates on either side. In this instance, they are sprung-loaded to keep them flush to the rudder. As usual, card templates are used to make up the lower ply covering on the fuselage...
tjarko
Post by tjarko »
Nice scale details!
Is the rudder counter weight functional?
No, the model doesn't fly fast enough for it to matter...
