Page 3 of 10
Re: MINIMOA 1/4 SCALE
Posted: 30 Nov 2020, 08:14
Once the elevator false LE is hinged up, the TE & ribs can be added. Once complete, the elevator is sanded flush to the tailplane.
Posted: 01 Dec 2020, 08:21
Now it's time for the elevator actuation arrangement: Hopefully, the pics should be self-explanatory. Because the servos are difficult to access, they are mounted on a removable plate should any maintenance be required.
Posted: 02 Dec 2020, 08:17
Now the rear end of the fuselage can be closed up. Note the rudder cable guides that will be embedded inside the ply outer covering...
Posted: 03 Dec 2020, 10:05
Time now to put the rudder together: as I don't seem to have any pics of the process, I've used the ones from the 5th scale build, which, apart from the size, is pretty much identical...
Posted: 04 Dec 2020, 09:49
On the full-size, the gap between the rudder and the fuselage was covered by hinged plates on either side. In this instance, they are sprung-loaded to keep them flush to the rudder. As usual, card templates are used to make up the lower ply covering on the fuselage...
Posted: 04 Dec 2020, 13:43
by tjarko
Nice scale details!
Is the rudder counter weight functional?
Posted: 04 Dec 2020, 15:05
No, the model doesn't fly fast enough for it to matter...
Posted: 04 Dec 2020, 15:38
chris williams wrote: ↑04 Dec 2020, 15:05
Usually......
Posted: 04 Dec 2020, 20:34
by SedB
I really enjoy looking at your builds, quit jealous of your pace (I think balsa shortage as a result of building windmills is a hoax, it's you building gliders 24/7 not!?)
I'm looking forward to see this model come along!
Posted: 05 Dec 2020, 08:16
A quick tidy up of the wheel mount...
