MINIMOA 1/4 SCALE
Re: MINIMOA 1/4 SCALE
Adam, although the HQ section is different to the Gottingen 681 section of the full-size, the wings are set at the same relative angle to the fuselage. The tailplane is then set 1.2 to 2 degrees negative to the wing. Of course, manually attaching the wing to the fuselage can be slightly hit & miss if you're not careful, but the incidence gauge keeps you on the straight an narrow...
Once the the gaps have been filled with balsa, the fairings are finished off with filler...
Now to set up the spoilers...
Time for gritted teeth...The Canopy
The small compound curved part at the front is achieved with the use of a clear plastic lemonade bottle, but if I was to do it again, I'd use the one-piece top segment, as I did with the 5th scale version. I suspect that the moulding I had made at Sarik for the MO2a would do the job nicely...
Just a few details left, now...
Note: the servo aperture is covered with a patch of vinyl that is colour-matched to that part of the wing:
Note: The TE gussets on the ribs were not originally fitted, but were retro-fitted when the opaque film covering was removed and replaced with the matt clear
A few details of the finished airframe...
The current state of the Minimoa with its translucent finish... (The 5th scale version is shown for comparison)
terry white
Post by terry white »
Chris, That's absolutely superb mate. I followed your build with interest.
A good build thread, with lots of pici's and a great model at the end. can't wait to see it fly.
john greenfield
Post by john greenfield »
Hi Chris
What do you do to "prime" the HK film before painting.
I think it is all film on the wings....
