HABICHT QUARTER SCALE
John Fairbairn
Re: HABICHT QUARTER SCALE
Post by John Fairbairn »
That looks like a rather nice paint jpb there Chris. I will be doing mine in the red sunburst, I hope.
At the moment it's progressing slowly as a short while back I managed to screw up my left shoulder and couldn't do much, but it's a lot better now and I'm trying to work things out. I decided to go off plan and cut the ailerons about 1/3rd 2/3rds with the inner 1/3rd to be a flap/aileron. All I have to do now is to work out how to program that into my Tranis Tx. If anyone has any ideas as to how to do this I would be very pleased to here it.
What I want to do is to be able to use both inner and outer sections as ailerons and the inner as flaps. The reason being is all that I have read about the spoilers not being very effective.
John.
mjcp
Post by mjcp »
John Fairbairn wrote:
27 Apr 2021, 13:39
You might have some luck with the excellent templates from Mike Shellim.
The F3F one is the "go to" for my full house gliders, I just ignore the bits that are not relevant or adapt e.g. spoilers but no flaps? Set the spoilers for "crow" in landing mode, but not for thermic/climb modes etc.
Where you may "come undone" is if you have both Flaps and spoilers, but if you say the spoilers are a bit "meh", ignore them and use crow.
n.b. all this assumes you are OpenTx, not OEM Taranis!
https://rc-soar.com/opentx/setups/f3f/index.htm
m̶j̶c̶p̶ Marc
Hanger -
27 Apr 2021, 13:39
John,
If you have the OpenTx OS on your Taranis then mixing anything with anything is possible. Essentially, if you can think of something, you can probably do it :)
Not sure what is possible on the default system as I changed my Tx to OpenTx pretty quick!
John, the combination of spoilers and up-going ailerons are usually very effective...
John Fairbairn
Thank you Mark. I will look at the link very soon.
I had meant to say that my tranny is on the Open Tx OS and I had realised that anything is possible, but it's the how that leaves me behind at times. I now have the wings fully operative, ailerons, flaps and spoilers and I think that I may even be on the right track for the flap/aileron mix?
I'll give it some more time tomorrow as my beer is going to get cold :shock: :shock:
That sounds promising Chris. I have used that on my Discus2 plastic thing. It certainly slows it down and makes things less 'interesting'! So with flaps as well ???
John.
John Fairbairn
I remembered to get a couple of photos of the flap arrangement today and I think that it should be quite effective.
Also, I managed to get 10 sheets of good quality 1/16th balsa on Saturday and have almost finished sheeting the underside of the Stbd wing. As the spoiler and flap servos are so close together I have put them under the same access hatch as I thought that it would look a real mess if they had separate hatches. It seems to have worked well and I used 1/16th ply for that
I thought of a simple servo mount. I glued a piece of 1 1/6th ply to the rib with a cutout for the servo and 4 servo mount screws, with the heads cut
The servo is held on the stumps with 2 bent wire clips
And it is a solid as a rock. I don't know if this method has been used before, but I have used it a couple of times and it's very secure.
John.
