HABICHT QUARTER SCALE
Re: HABICHT QUARTER SCALE
Once the outside of the front of the fuselage has been filled and shaped, the temporary formers can be removed, and the interior glassed in the usual fashion...
Once the false LE has been hinged to the tailplane, the construction of the elevator can commence...
The tailplane can now be mounted to the fuselage and the elevator connected to the servo...
With the wing joiner box made up, it's time for an alignment check before glueing it in place...
