Please support this charity auction in memory of our dear friend Geoff Pearce for his favourite cause"Marie Curie" setup by Terry White. https://scalesoaring.co.uk/sailplane-auction/
SCALE: 1/4
SPAN: 3.4m
WEIGHT: 15lbs
WING SECTION: HQ35/14-12
5-FUNCTION CONTROL FOR RUDDER, ELEVATOR, AILERONS, TOW RELEASE, SPOILERS
Deviations from scale: top-hinged ailerons, fuselage slightly thinned in width,
no elevator trim tab, non-scale wing section, no tailplane struts
I've not had that many opportunities to fly the Habicht, but here are my conclusions:
1: Perfectly safe at low speeds, as you would expect with this section
2: Capable of all the standard aerobatic manouvres, loops, rolls etc. (A bit untidy, but that's more than likely down to me!)
3: Capable of sustained inverted flight
The big lump of lead up front certainly goes a long way toward retaining energy during aerobatics. In common with every other Habicht I have built, you would need Big Lift on the slope, otherwise you will spend a lot of time trying to get some altitude before you can rapidly spend it. Aerotow is the better option, as you can start with plenty of height before hooning begins. Like it's bigger predecessor, such a flight will last 2 to 3 minutes.
Also, for those who enjoy Scroll Saw Therapy, the parts are available from me in PDF form, all ready to print out in an A4 printer. (Note: always check the printout outs against the plan)
