Page 12 of 13
Re: ASK13 1/3 Scale
Posted: 07 May 2021, 20:06
john greenfield wrote: ↑07 May 2021, 08:14
I actually use "Balsaloc" to attach the covering as you can just iron the covering on with a low temp iron (not hot enough to shrink the covering but enough to activate the Balsaloc). Once attached I brush dope around the edges and any undercamber to lock the covering to the structure and then start the shrinking process with a hotter iron.
How do you get to the under camber, after you have sealed the edges??
Re: ASK13 1/3 Scale
Posted: 07 May 2021, 21:13
Just leave the covering slack enough to be able to get it to reach the under cambered ribs Barry, then shrink to tighten once secured.
Re: ASK13 1/3 Scale
Posted: 07 May 2021, 21:58
Prototype 3D printed seat checked for size.
Improved ones with full scale cutouts to be fitted in due course.
Re: ASK13 1/3 Scale
Posted: 08 May 2021, 07:59
by john greenfield
Barry_Cole wrote: ↑07 May 2021, 20:06
I attach to the root and tip first and then starting at mid chord work forwards and backwards attaching it to the undercamber before securing it to the leading and trailing edges !!
Re: ASK13 1/3 Scale
Posted: 16 Jun 2021, 14:00
Re: ASK13 1/3 Scale
Posted: 15 Jul 2021, 16:05
Paint job done just decals to add.
Re: ASK13 1/3 Scale
Posted: 15 Jul 2021, 16:43
by StephenB
What a striking model, beautiful job as ever Peter.
Re: ASK13 1/3 Scale
Posted: 15 Jul 2021, 17:58
Paint job isn’t mine , but nice work anyway
Should look even better once the decals are on.
Re: ASK13 1/3 Scale
Posted: 16 Jul 2021, 15:10
Re: ASK13 1/3 Scale
Posted: 16 Jul 2021, 18:46
by catwok
Beautiful looking model Cliff, mine will only come out after sun set now!
