ASK13 1/3 Scale
Re: ASK13 1/3 Scale
I am only limited by the size of the printing bed, what scale do you require?
Re: ASK13 1/3 Scale
33% and 40% if possible
Re: ASK13 1/3 Scale
Picture of the previously featured full size tailskid parts re-assembled back onto the glider after refurbishment.
Re: ASK13 1/3 Scale
With a bit of sunny weather upon us & the 2nd wing structure now at the same build state as the 1st, it’s time for a trial assembly
Next job is to prepare the balsa spar caps & False LE for applying the top skin.
- Barry_Cole
Re: ASK13 1/3 Scale
Brian will be after you about that grass!!!
Re: ASK13 1/3 Scale
You should have seen it before I cut it
- Max Wright
Re: ASK13 1/3 Scale
It's a beautiful thing, Peter.
Almost a shame to cover all that lovely work.
Max
- B Sharp
Re: ASK13 1/3 Scale
The grass is Ok Peter. Keep the cut hight high for the first cut, a quick scarrify and a spring feed to finish!
The aeroplane is not looking too shabby either.
