Falke T-61A Cliff Charlesworth Plans.**
Max Wright
Post by Max Wright »
This is the subject. It formed part of the South Australian Scouts Association Air Division.
This is my research sheet and Cliff's book.
T-61A 1.JPG (11.16 KiB) Viewed 5637 times
Here is my new steel build table (Zincalume on 16 mm MDF).
And my magnetic building devices.
I found that when I unpacked it, the two Ribs 1 had been inadvertently left out. Cliff (Evans), tried to post me replacements but they fell victim to the COVID lurgy and disappeared into the ether. So I made two more from copying the others. Good practice. 8-) Thanks for trying, Cliff. ;)
To get my head around the different angles of the wings, I tried a new strategy. I assembled fuselage frames 3,4 and 5 and installed the Rib sisters to those frames.
[attachment=0]T-61A 8.JPG[/attachment
This gave me a jig to set up my wing spars.
More to follow . . .
Max
Max Wright
Re: Falke T-61A Cliff Charlesworth Plans.
Here the two spars are being built.
And now the Graupner boxes are being epoxied in place.
Now I can build each wing around its spar and hopefully they will sit correctly.
Fingers crossed . . .
Max
Max Wright
OK On we go . . .
I will live to regret glueing those rib sisters in place, but . . .
When I checked Rib 1 with the plan, it was 5 mm too long. Remember their sisters?
So, I fixed the spar and the trailing edge on the plan and ignored the overhang.
I laminated some 3 mm balsa and set about adding the front sections of the ribs.
I made a device for sitting each rib on the table and measuring where to cut 9 mm off its nose.
It all worked out well.
Max
Max Wright
Still more . . .
For a bit of a diversion, I installed the first of the wing joiner anchors.
Then I found that the balsa wing tip rib was very flimsy and easily damaged (how did I find this out?), :oops:
So I cut sisters out of 3 mm ply and added them.
Max
Max Wright
We're in the home stretch . . .
Keeping the spar and trailing edge firmly locked on to the plan, I then cut the ribs and glued them in place.
. . . and continued to assemble the other woody bits to the device.
You can see that I've remembered the crank. The washout has also been incorporated on the tip end. ;)
Also the wing joiner anchor and the anti-rotation pin are now in place.
Tomorrow, the remaining woody bits go on the top and the whole catastrophe will be turned over and wooded. :ugeek:
Then, it's on to the aileron.
Woo Hoo!
Max
Well done Max. Its looking good :)
Max Wright
Thanks, Peter. 8-)
Max
Max Wright
I have to deal with another diversion. :?
Remember that I made a jig out of fuselage frames 3,4 and 5?
Well, I've discovered that frame 4 is 4 mm narrower than it should be.
No biggie - I made a doubler out of 3 mm balsa and glued it on to the sister.
Then I used my 1.1 metre sanding bar to fair it in.
I'll do the other side later.
Max
Max Wright
I think that I've got the wing worked out . . .
I might leave it there and get the left one to this stage before I move forward (also while I can still remember what I did). :lol:
Max
That's coming along nicely Max. There is no need to forget your progress, just use your photos from this build thread.
