Falke T-61A Cliff Charlesworth Plans.
Re: Falke T-61A Cliff Charlesworth Plans.
Post by Trevor »
It's shaping up very nicely now Max. Now that you mention it, I seem to remember a fair bit of shimming and sanding to get those huge wing roots to sit well against the fuselage.
Max Wright
Post by Max Wright »
Thanks, Trevor.
That makes me feel a lot better. 8-)
Max
Coming together well now.
Well don Max
Laser Cut sailplanes
Max Wright
Thanks, Cliff. 8-)
Max
Max Wright
Today, Sunday 7th January was spent laminating the spoilers.
The plans say two layers of 3.0 mm balsa, but the balsa I have is very soft. I've laid up two layers of 2.5 mm balsa with a 0.4 mm ply layer each side.
The control horns are piano wire bent into a loop at the ends . . .
The eyes are filled with "Knead it" epoxy filler, which will be drilled to accept the clevis'.
Max
