Zephyrus from down under
Re: Zephyrus from down under
The top bit certainly looks moulded Vince - either way, the 'join' would be easy enough to simulate.
Not a lot of progress as I am awaiting the canopy. I will probably start the wings in the New Year
  • The wheel fairing has been completed prior to finalising before painting
    The skid fittings have been made and added. The rear fitting allows the skid to move backwards on impact as per full size
    All servos have been fitted
    Mock frame tubes added to the sides from 6mm dowel
    Cockpit sprayed
    and finally the Seats made
The nose will be finished later when I know what balance weight is required
ARUP
Post by ARUP »
Looks great! Thanks for posting!
My life is still in turmoil and I haven't been able to post to this thread for a while or give a blow by blow account, but I have finally got one wing shaped up with now all the ancillary work to do
Looking really good Vince - keep at it.
terry white
Post by terry white »
Hi Vince,
Far from 'amateur status' This is a great build log. I love it when builders show the things that go wrong as well as the things that go right, needing great thought and ingenuity to get around the problem,shows me that Im not the only one.You know what I mean,your watching T.V. but your mind is in the workshop.Your wife is having her one way conversation with you while your working out how to deal with the latest problem, and saying yes to her mother coming to stay and wanting a new outfit for the purpose!! You go to bed but can't sleep,you toss and turn with the problem running around and around in your head.The birds start to sing so you know its morning and you have to be up in an hour to go to work.These are the beautiful things that ARTF fliers will never experience, poor souls. ;) Regards Terry.
Great stuff, Vince. Keep it up.
Building continues with the skinning of the wing top and bottom and installation of top and bottom opposing opening airbrakes.
Progress was delayed due to problems with the aileron hinging. The original was top hinged and a complicated progressive rotation of the outer wing requiring the rib nose to be dropped allowed the top hinge line between the aileron and wing to remain straight on deflection. Unfortunately I failed to achieve this almost impossible task and went for an easier centre hinge
You know when you are taking a long time when you have to search a long way down the Topics to add another post. The project is still under way and I have finally got the second wing just about built. All I can say is I am glad it's not a bi-plane. The second wing went easier than the first as I was aware of all the pit falls and will have to go back to the first wing at some time to make a few minor mods.
One of my new problems is the method of securing the wings to the fuselage. The top of the fuselage cabin is glazed and rubber bands stretching across would be intrusive, so I am trying a system I heard of many years ago by using TENAX fasteners, which are used for securing the hood to the bodywork of convertible cars. The ones I purchased have a 1" stud with a 2BA thread. Fortunately the thread seems to be common to 5mm, so I have placed a 5mm 'T' Nut on the inside of the wing. The holding attachment is spring loaded so that a pull on the domed head release the connection. Well that's the theory over......
ARUP
Post by ARUP »
It sure has a pretty wing!
