MINIMOA MO2a 3.5 SCALE
Re: MINIMOA MO2a 3.5 SCALE
Time to make up the all-moving rudder and install the rudder cable guides. Unlike most sailplanes, the rudder guides exit out of the rear former, rather than the sides of the fuselage, so there's not a lot of room when connecting up...
Now it's time to start on the wings. These are built with my old method i.e. built in two panels, later joined at the gull break.
Now the outer and inner panels can be jigged up and joined together...
Before the lower sheeting is added, a straight edge clamped to the aileron spar keeps the outer wing panel straight. Before adding the top sheeting, the two small parts of the inner panel TE are clamped to keep them parallel...
After a quick dihedral check, the wing can be placed on the jigging supports and the top sheeting added...
A quick progress check, then on with finalising the wing sheeting...
Now it's time to sort out the fitting of the wing joiner box...
A bit more work on the fuselage now, including adding a strip of 3mm sq spruce strip to form a rebate for the glazing, and sorting the hole for the landing light...
