MINIMOA MO2a 3.5 SCALE
Re: MINIMOA MO2a 3.5 SCALE
With the skid glued on and the MPX tow release temporarily installed, attention can now move towards fitting the wings to the fuselage...
Note that the rubber retention bands sit closer together than usual, in order to hide their existence inside the joiner box assembly in the fuselage.
Lookin good Chris, could you please tell me where you get you servo cable from on the roll? Thanks
Keith
Keith
I'm pretty sure I got it from Overlander...
Keith,
An alternative source is the Component Shop for cable & conectors.
https://www.componentshop.co.uk/cable/servo-wire.html
- Barry_Cole
Yes, I use that, it's great.Peter Balcombe wrote: ↑01 Feb 2021, 12:57Keith,
The wing root fairings are finalised the usual way with filler...
- Barry_Cole
Are you having a lay in these Days? These posts are getting later and later.
It’s to give him more time to do the tricky bits BarryBarry_Cole wrote: ↑04 Feb 2021, 12:45Are you having a lay in these Days? These posts are getting later and later.![]()
