Slingby Kirby Kite 1:3 Jilles**
Jolly Roger
Post by Jolly Roger »
etc...
Jolly Roger
getting bored yet?
Jolly Roger
and finally...
Jilles
Post by Jilles »
Thankyou for sharing the pictures
does somebody know how many Kirby Kites were built by Slingsby
Jilles
Jolly Roger
25 produced according to Slingsby Sailplanes by Martin Simons, with production ceasing in 1939 (when they cost £159! each).
There was a Type 23 Kite variant made after the war. Its wing was mounted higher on a streamlined pylon, and it had spoilers as standard plus a mainwheel. I've only found two photos of it, one in the Simons book and one copied from a photo borrowed from vintage sailplane enthusiast Ted Hull. The sole Type 23 went to the USA then disappeared.
I'm feeling like a proper vintage sailplane nerd here. :D
Jolly Roger
... and I've got the BGA numbers for all 25 Kites from the Normal Ellison book if that helps anyone.
That's me - I'm all anoraked out. ;)
Jolly Roger
One more thing Jilles: I see your diagonal strip method is also used on the full-size.
Jilles
Post by Jilles »
got the diagonal idea from attache picture.
Jilles
Re: Slingby Kirby Kite 1:3 Jilles**
Post by Jilles »
First wing in progress. The spar is pre assembled including brackets for fuse pin and struts. Building tabs on some parts help with the with building the wing level on the board. A jig was made from Nc parts to aline the three fuse pickup points at the fuselage. These brackets are to scale. The strut will be load bearing so no wing joiner tubes. Today I added a vertical board to my bench to have the wing vertical so access to the D-Box is to both sides. The planking will be wrapped around sections from 0.4mm plywood of around 300 mm long. This way there will be no joint in the planking at the L/E. the finish will be clear varnish so a joint is not what I want to see.
The L/E has solid balsa between ribs to support the Planking over the tight radius. this still needs to be sanded into shape.
spar pre work
spar pre work
air brake area
air brake area
build tabs
build tabs
t/e in progress
t/e in progress
pin jig
pin jig
t/e planked
t/e planked
wing located vertical
Balsa L/E  waiting to be sanded
