Page 1 of 6
Pat Teakle Asw 22 6m**
Posted: 12 Mar 2021, 22:42
by Dave Mackintosh
Hi all. Thanks to the legend that is Cliff Evans,I have aquired the 6 meter Asw 22.I thought I would begin a build thread,
Tail feathers are nearing completion,(photos to follow).
Re: Pat Teakle Asw 22 6m
Posted: 12 Mar 2021, 22:51
by Max Wright
Watching . . .
Posted: 12 Mar 2021, 23:09
by Dave Mackintosh
I have servos in mind for tail feathers, around the 11 to 15 kilo pull.Your thoughts gentlemen?
Posted: 13 Mar 2021, 07:13
by Andrew Ray
Hi Dave, built up or foam wings and tail?
I have fitted a Hitec HS-225BB mini servo in the tail of my Pat Teakle ASW17 on 4.8v it does the job. I would go for a standard servo, probably with a ball race on the output shaft (the old JR591 running on 4.8volts was always my servo of choice but no longer available unfortunately), Hitec, Savox or similar, like the SG-0351 or SV-0320. 4 to 5kg of torque is more than plenty. High voltage/high torque servos weren't around when Pat was producing these and the standard Futaba 148 was more than adequate and reliable back then.
Posted: 13 Mar 2021, 08:32
by roo Hawkins
Watching. Good luck with the build.
Posted: 13 Mar 2021, 09:09
I would use one of these:
https://airtekhobbies.com/hv2107mg.html
Nice half scale pilot by the way!
Posted: 13 Mar 2021, 13:54
by Dave Mackintosh
Andrew Ray wrote: ↑13 Mar 2021, 07:13
Thanks for the info Andrew, I will be using cnc foam panels.
by Dave Mackintosh
Posted: 13 Mar 2021, 14:08
Posted: 13 Mar 2021, 14:38
I would have thought that either of the last 2 servo suggestions would be fine & are
smaller than the original Futaba S148 or S3001 types that Pat would have had available when the model was designed.
The old Futaba standard servos produced around 3Kg/cm torque.
