Ls8 neo
Ls8 neo
I was not planning on building anything for a while. But decided I would like a smaller glider with electric motor so I can fly it any where glider . So I started a ls8 neo the full size is front electric system so will be scale. Was looking at the multiplex gliders but did not want to pay that for a foam glider even if they are good. When I can build a glass and foam veneer one for less. Span will be around 3.2 to 3.3
Re: Ls8 neo
Dave Mackintosh
Re: Ls8 neo
Post by Dave Mackintosh »
Good luck Roo. I'll be watching this build.
Max Wright
Re: Ls8 neo
Post by Max Wright »
Signed on, Roo.
A good choice. 8-)
Max
Re: Ls8 neo
All the foam parts made but the fuselage snapped doing the hole for the wings. Glued all together again. Finshed with polyfilier. Ready for sanding.
Re: Ls8 neo
Some of the fuselage glassed but have not anymore glass. Easy compersits have no 200gm glass and glass balloons in stock so it is on hold tI'll it's in stock
mjcp
Re: Ls8 neo
Post by mjcp »
Plan "b" or "Plan Neo" ?
https://www.bucks-composites.com/
M
m̶j̶c̶p̶ Marc
Hanger -
Re: Ls8 neo
Thanks Marc. But I have finished with scrap bits of glass and a strip of carbon.
Re: Ls8 neo
Decided to make the fin our of foam veneer
terry white
Re: Ls8 neo
Post by terry white »
Hi Roo, hope you and the Mrs. are well.
I'm interested to see how you are going to run the servo power and mechanics to the tail plane
and attach the fin to the fus strong enough to withstand landing loads etc.
