Cliff Charlesworth Ka3 from LCS
TonyL
Re: Cliff Charlesworth Ka3 from LCS
Post by TonyL »
3mm copper tube annealed and shaped using 2 mm brake cable
TonyL
Post by TonyL »
canopy tubes soldered together
TonyL
Post by TonyL »
used aluminium foil to act as heat sinks
canopy placed on fuzz
TonyL
Post by TonyL »
wings and v-tail assembled/aligned
TonyL
Post by TonyL »
tow release and servo
TonyL
Post by TonyL »
battery to be fixed with scratch tape
TonyL
Post by TonyL »
V_TAIL DAMAGE REPORT:
During the v-tail assemby the 2 mm balsa - 2mm steel wire interface proved fragile! It is strongly
recommended to epoxy a .4 mm ply panel over the entire width of the last 5 cm's!
The picture shows the original setup that should be reinforced!
