TonyL
Post by TonyL »
Major modification of the rubber skid support, using a squash ball,
squash ball cradle from 3 mm ply to support landing skip
TonyL
Post by TonyL »
cradle with squash ball to support landing skip
TonyL
Post by TonyL »
first rough balancing with the V-tail indicates 500 grams of lead in the nose
(not including the battery) when the fuzz is covered and painted I will fine-tune
the balance
the nose is build-up from balsa and 500 grams of lead glued to the formers, top, side, bottom and front views
TonyL
Post by TonyL »
nose glassed
TonyL
Post by TonyL »
canopy latch
TonyL
Post by TonyL »
canopy frame from 3mm and 2 mm annealed copper tube,
using alu-foil as heat radiators to keep everything together
TonyL
Post by TonyL »
Help request for canopy glassing:
using polyzap on 0.5 mm rhodoid (hope this is English) caused
a brittle bond and brittle cracks in the rhodoid.
using epoxy glue avoided the brittleness but the joint with the
rhodoid was weak at best (used alcohol to clean and 300 grit
sandpaper to coarsen the rhodoid for the glue joint.
ps: used the polyzap on some other thin plastic transparent
material, glue joint was good, but the plastic became very
brittle aswell!
any suggestions are very welcome!
TonyL
Post by TonyL »
skid and squash ball damper installed
TonyL
Post by TonyL »
skid covered (not sure it will last as there are some rocky parts on our flying hill)
TonyL
Post by TonyL »
and the picture
