front brace notched to clear stringers
rear brace holes plugged and new holes drawn to generate the required 2.5 degrees tailplane incidence
v-tail covered in DIACOV
adding a 3 mm spacer, the v-tail is horizontal: angle = 2.2 degrees, close enough, please note
that the front brace was temporarily thickened to 20 mm
v-tail horizontal in the span direction
M2 screws in V-tail rear brace, notice gap between brace and stringers
V-tail center cover from 1 mm plywood
V-tail - 2 mm steel screw epoxied into 6 mm carbon rods, 3 mm copper tube increases the glue surface, carbon tube: 20 grams each
elevator painted, ball epoxied to 2 mm horn at 30 mm from bend, weight 29 grams
