Cliff Charlesworth Ka3 from LCS
TonyL
Post by TonyL »
front half of ribs fitted, spacers used to clear fittings
TonyL
Post by TonyL »
glued false leading edge, spacers used to clear fittings (from the building board)
TonyL
Post by TonyL »
plywood root rib on 3 mm balsa part (to compensate for angle), root rib sanded down a little
TonyL
Post by TonyL »
skinned one side (white glue ironed on)
TonyL
Post by TonyL »
second skin ironed on, ruler is used for alignment and spacer
TonyL
Post by TonyL »
0.4 mm skins sanded down to the false leading edge
TonyL
Post by TonyL »
6 mm balsa leading edge glued on, rear rib-halves aligned and glued on, 0.8 mm plywood
trailing edge and balsa thickeners glued on
TonyL
Post by TonyL »
rear half of root rib glued on and reinforced
TonyL
Post by TonyL »
aileron spar and subspar
TonyL
Post by TonyL »
doubled rib (cardboard spacer) and reinforcements
