3mm copper tube annealed and shaped using 2 mm brake cable
canopy tubes soldered together
used aluminium foil to act as heat sinks
canopy placed on fuzz
wings and v-tail assembled/aligned
tow release and servo
battery to be fixed with scratch tape
V_TAIL DAMAGE REPORT:
During the v-tail assemby the 2 mm balsa - 2mm steel wire interface proved fragile! It is strongly
recommended to epoxy a .4 mm ply panel over the entire width of the last 5 cm's!
The picture shows the original setup that should be reinforced!
landing skid from 2 x 3 mm plywood
tapered to 1 mm thickness and 1mm dural insert at front
tapered skid thickness at rear end
