Page 12 of 14
Re: Cliff Charlesworth Ka3 from LCS
Posted: 30 Jul 2021, 16:27
by TonyL
two skid parts epoxied together and cleaned up
Posted: 30 Jul 2021, 16:28
by TonyL
M 5 brass insert made from M 5 screw with M3 allen bolt
Posted: 30 Jul 2021, 16:29
by TonyL
M 5 brass insert epoxied into hardwood block
by TonyL
dural strop bolted to ply-balsa ply sandwich of 15 mm thickness
- fb34s.JPG (13.09 KiB) Viewed 1386 times
Posted: 30 Jul 2021, 16:30
by TonyL
front of skip bolted to fuzz
Posted: 30 Jul 2021, 16:31
by TonyL
rear of skip in dural strop
Posted: 30 Jul 2021, 16:32
by TonyL
3 mm ply reinforcements between formers 4 & 5, 4 mm balsa reinforcement aft former 5
Posted: 08 Aug 2021, 14:39
by TonyL
Finished building the other wing, cut a little jig to sand the leading edge, the ribs look
very simplar to the original Ka 3 profile: Göttingen 549, 14% maximum thickness and a
leading edge defined by only a few points
Posted: 08 Aug 2021, 14:41
by TonyL
Both wings covered in DIACOV
Posted: 08 Aug 2021, 14:43
by TonyL
3 mm ply reinforcements behind former 5
