Cliff Charlesworth Ka3 from LCS**
Posted: 18 May 2021, 19:07
by TonyL
Hello everybody, this is my first build thread, but not my first build.
I took some pictures and will post them here, together with my remarks.
Cliff C's plan is very clear, but I might have misread some parts, and some
details like the CoG are missing, so I hope I can get some input from you.
The short kit is very well cut from top notch balsa and ply, but I had to recut
some parts (several times as I made plenty mistakes)
If I would build the wing a second time I would have built the spar classically.
Cliff Evans cut the jig and added it, and I donot think one can build the fuzz without the jig!
Some dimensions of the wood (balsa and spruce) were modified as these sizes
were not available in France
Instead of 4.5 mm square hard balsa sticks I used 4 mm Samba (Obeche) and the
6x4.5 mm spruce keel was made from two 5x3 mm spruce sticks glued together
Re: Cliff Charlesworth Ka3 from LCS
Posted: 18 May 2021, 19:14
by TonyL
The jig supplied by Cliff Evans, I had to modify some parts to
account for the skid, which explains the "amateur" Iook, and
added the tail post as it helps positioning the keel, I downsized
the pictures 4 times to keep the file-size down,
please let me know if you prefer larger pictures
Posted: 18 May 2021, 19:16
by TonyL
the four main stringers (4 mm obeche) steamed (roughly) to shape
Posted: 18 May 2021, 19:18
by TonyL
Formers 1-7 on the jig and the main stringers glued in place
Posted: 18 May 2021, 19:21
by TonyL
wing saddle built (not 100% sure it is as CC planned)
Posted: 18 May 2021, 19:26
by TonyL
built the top of the rear fuzz flat on the plan and positioned it in 3d using the jig
then added the braces (all 4 mm obeche)
Posted: 18 May 2021, 19:28
by TonyL
rear fuzz and formers 6 & 7
Posted: 18 May 2021, 21:39
Hi Ton. CG is as in the picture.
Posted: 24 May 2021, 17:27
by TonyL
Hi Cliff,
thanks very much for the CoG location, I made some more progress
Posted: 24 May 2021, 17:30
by TonyL
cockpit floor below seat, 4 mm obeche
Posted: 24 May 2021, 17:31
by TonyL
Posted: 24 May 2021, 17:32
by TonyL
some more progress on the tail
Posted: 24 May 2021, 17:34
by TonyL
Posted: 24 May 2021, 17:41
by TonyL
fittings were hand "crafted" using 1.5 and 1 mm dural, will try to see if
I can replace them with a set of higher precision!
former 4 with 1.5 mm dural fittings,
former thickened with 1mm ply front and aft for top fitting
thickened with 1 mm ply front for bottom fitting,
top: space between fittings is now 5 mm (1+3+1) and the wing-spar-fitting fits inside
bottom: space is 4 mm for the copper fitting on strut (see later)
Posted: 24 May 2021, 17:43
by TonyL
former 6 with 1mm dural fitting for v-tail
Posted: 31 May 2021, 08:35
by TonyL
putting the fuzz aside and starting on the wings, as I stated before, if I'd build them again
I would go the classical way: notch the ribs, insert the spruce spars, add balsa shear webbing
(reinforced with ply where the fittings are located) I had serious problems aligning the
trailing edges as the ply part of the main spar has mainy holes.
Anyway, gluiing the 3x5 mm spruce sticks to the ply part using white wood glue
Posted: 31 May 2021, 08:37
by TonyL
second stick glued to spar (this way the spars are straight though!)
Posted: 31 May 2021, 08:39
by TonyL
Strut fitting front and rear of spa, used 3 mm ply as filler, the fittings are 4.5 mm apart
Posted: 31 May 2021, 08:43
by TonyL
Fuzz fittings directly onto the 1.5 mm ply, no reinforcements necessary as
the struts take up much of the load. the outside of the fittings is 4.5 mm apart
therefor the fittings on former 4 had 1 mm ply backings front and aft
(3 mm ply + 1+1 mm =5mm)
Posted: 31 May 2021, 08:45
by TonyL
a very simple rig for cutting the ribs, as most are the same
Posted: 31 May 2021, 08:46
by TonyL
front half of ribs fitted, spacers used to clear fittings
Posted: 31 May 2021, 08:48
by TonyL
glued false leading edge, spacers used to clear fittings (from the building board)
Posted: 31 May 2021, 08:50
by TonyL
plywood root rib on 3 mm balsa part (to compensate for angle), root rib sanded down a little
Posted: 31 May 2021, 08:51
by TonyL
skinned one side (white glue ironed on)
Posted: 31 May 2021, 08:53
by TonyL
second skin ironed on, ruler is used for alignment and spacer
Posted: 06 Jun 2021, 15:49
by TonyL
0.4 mm skins sanded down to the false leading edge
Posted: 06 Jun 2021, 15:53
by TonyL
6 mm balsa leading edge glued on, rear rib-halves aligned and glued on, 0.8 mm plywood
trailing edge and balsa thickeners glued on
Posted: 06 Jun 2021, 15:54
by TonyL
rear half of root rib glued on and reinforced
Posted: 06 Jun 2021, 15:55
by TonyL
Posted: 06 Jun 2021, 15:57
by TonyL
doubled rib (cardboard spacer) and reinforcements
Posted: 06 Jun 2021, 15:58
by TonyL
aileron cut out and cleaned up
Posted: 06 Jun 2021, 16:00
by TonyL
aileron subspar simplified (shortened) and installed
Posted: 06 Jun 2021, 16:23
That is coming on well Tony.
Posted: 12 Jun 2021, 18:50
by TonyL
Thanks Cliff,
thanks,
hope this Ka3 will fly this summer!
Posted: 12 Jun 2021, 18:56
by TonyL
fitting installed on subspar shear webbing (only top spruce glued)
Posted: 12 Jun 2021, 18:58
by TonyL
by TonyL
Posted: 12 Jun 2021, 19:00
by TonyL
aileron hinge (2mm steel wire+1mm dural) let into 2 mm balsa false leading edge
- wb21s.jpg (19.93 KiB) Viewed 1117 times
Posted: 12 Jun 2021, 19:01
by TonyL
Posted: 12 Jun 2021, 19:02
by TonyL
balsa semi-rounds, rhs: balsa semi-rounds covered in 0.4 plywood
Posted: 12 Jun 2021, 19:03
by TonyL
plywood covered side faces hinges
Posted: 12 Jun 2021, 19:04
by TonyL
pre-shaped 0.4 mm plywood covers the aileron leading edge
Posted: 20 Jun 2021, 19:48
by TonyL
2mm piano wire epoxied into 2mm balsa false leading edge
Posted: 20 Jun 2021, 19:50
by TonyL
2mm trangular ribs for the airbrake, 0.4 mm plywood ironed on, reinforcement for the drive arm
Posted: 20 Jun 2021, 19:51
by TonyL
1.5 mm dural drive arm epoxied into place at roughly 45 degrees
- wb28s.jpg (16.23 KiB) Viewed 1071 times
Posted: 20 Jun 2021, 19:52
by TonyL
4 mm leading edge sanded round
- wb29s.jpg (6.47 KiB) Viewed 1071 times
Posted: 20 Jun 2021, 19:53
by TonyL
finished airbrakes light and stiff! 8 grams/piece
Posted: 20 Jun 2021, 20:00
by TonyL
1.5 mm plyrib reinforcement to take micro-servo
Posted: 20 Jun 2021, 20:01
by TonyL
rib reinforcement with servo
Posted: 20 Jun 2021, 20:02
by TonyL
air brake installed, servo installed (top view)
Posted: 20 Jun 2021, 20:04
by TonyL
air brake installed, servo installed (bottom view)
Posted: 20 Jun 2021, 20:05
by TonyL
Posted: 27 Jun 2021, 12:40
by TonyL
simple cap strips on aileron
Posted: 27 Jun 2021, 12:42
by TonyL
Posted: 27 Jun 2021, 12:43
by TonyL
ailerons covered in DIACOV
Posted: 27 Jun 2021, 12:44
by TonyL
Posted: 27 Jun 2021, 12:45
by TonyL
aileron shrouds and simple capstrips
Posted: 27 Jun 2021, 12:46
by TonyL
airbrake servo hatch ready to close
Posted: 27 Jun 2021, 12:47
by TonyL
Posted: 27 Jun 2021, 12:48
by TonyL
wing root with 6 pole Multiplex connector
Posted: 27 Jun 2021, 12:49
by TonyL
wing with simple capstrips
Posted: 27 Jun 2021, 12:51
by TonyL
right wing covered in DIACOV
Posted: 28 Jun 2021, 11:22
by Robcrad
Hi Tony,
what paint are you using on the Diacov? I am thinking of using Diacov on a 1/5th scale Mucha standard and I need to either match the white of the Diacov to paint the fiberglass fuselage or paint everything.
Rob
Posted: 04 Jul 2021, 12:21
by TonyL
Hi Rob,
I am using spray cans, the one on the left is primer/filler
the one on the right is "signal-white"
The paint is more expensive than car-paint, but at least the
white paint covers better!
procedure: clean diacov with alcohol, spray with primer, sand
gently with 400 paper, spray with paint
Posted: 04 Jul 2021, 12:27
Tony, 400 grit is a bit coarse for the primer, especially with an air-dry paint: better off with 600 or 800
Posted: 04 Jul 2021, 12:28
by TonyL
While finishing the other wing, I get back to posting pictures of the fuzz-build
5x3mm spruce stringer steamed to conform tail and glued into formers 6 & 7
Posted: 04 Jul 2021, 12:29
by TonyL
5x3 spruce stringers with 5x3 spruce spreader bars
Posted: 04 Jul 2021, 12:30
by TonyL
front end stringer steamed to shape
Posted: 04 Jul 2021, 12:31
by TonyL
front part stringer glued to all 4 mm braces
Posted: 04 Jul 2021, 12:33
by TonyL
top stringer glued and reinforced The fuzz structure is very light and very
stiff with respect to bending and torsion
Posted: 04 Jul 2021, 12:37
by TonyL
v-tail servo's symmetrical position
- fb18s.jpg (17.29 KiB) Viewed 1333 times
Posted: 04 Jul 2021, 12:39
by TonyL
v-tail servo's installed in removable tray
Posted: 04 Jul 2021, 12:44
by TonyL
Hi Chris,
thank you for your comment, I'll give the 600-800 paper a try
when painting the wings
Posted: 04 Jul 2021, 12:49
by TonyL
time for an update on the V-tail
2mm wire bent at correct angle
- tb1s.jpg (13.54 KiB) Viewed 1335 times
Posted: 04 Jul 2021, 12:50
by TonyL
2mm wire soldered onto copper plate wire let into the wood, wire and copper plate epoxied to wood
Posted: 04 Jul 2021, 12:51
by TonyL
Posted: 04 Jul 2021, 12:52
by TonyL
Posted: 04 Jul 2021, 12:53
by TonyL
hinges reinforced with 0.4 mm ply
Posted: 04 Jul 2021, 12:55
by TonyL
2 mm bent wire left and right
Posted: 04 Jul 2021, 12:56
by TonyL
half-rounds, top ones covered in 0.4 mm ply (facing hinges)
Posted: 04 Jul 2021, 12:57
by TonyL
pre-forming the (wet) leading edge of 0.4 mm ply around a steel tube
Posted: 04 Jul 2021, 12:58
by TonyL
half-rounds formers for leading edge
Posted: 04 Jul 2021, 12:59
by TonyL
half-rounds formers for leading edge and hinge
Posted: 04 Jul 2021, 13:01
by TonyL
half-rounds around hinge and shaped 0.4 mm ply leading edge
Posted: 04 Jul 2021, 13:02
by TonyL
elevator rear view and front view
Posted: 08 Jul 2021, 12:41
by TonyL
I will be travelling next week, so an early update:
elevator finished: 19 grams
Posted: 08 Jul 2021, 12:42
by TonyL
elevator covered: 25 grams
by TonyL
0.4 mm shroud and balsa reinforcement
Posted: 08 Jul 2021, 12:43
by TonyL
Posted: 08 Jul 2021, 12:44
by TonyL
v-tail front brace height temporarily increased to 20mm (= height rear brace) to simplify alignment
Posted: 08 Jul 2021, 12:45
by TonyL
front brace notched to clear stringers
by TonyL
rear brace holes plugged and new holes drawn to generate the required 2.5 degrees tailplane incidence
Posted: 08 Jul 2021, 12:46
by TonyL
Posted: 08 Jul 2021, 12:47
by TonyL
fuzz wing saddle horizontal
Posted: 08 Jul 2021, 12:49
by TonyL
adding a 3 mm spacer, the v-tail is horizontal: angle = 2.2 degrees, close enough, please note
that the front brace was temporarily thickened to 20 mm
Posted: 08 Jul 2021, 12:50
by TonyL
v-tail horizontal in the span direction
Posted: 08 Jul 2021, 12:55
by TonyL
M2 screws in V-tail rear brace, notice gap between brace and stringers
Posted: 08 Jul 2021, 12:56
by TonyL
V-tail center cover from 1 mm plywood
Posted: 18 Jul 2021, 19:51
by TonyL
V-tail - 2 mm steel screw epoxied into 6 mm carbon rods, 3 mm copper tube increases the glue surface, carbon tube: 20 grams each
Posted: 18 Jul 2021, 19:53
by TonyL
elevator painted, ball epoxied to 2 mm horn at 30 mm from bend, weight 29 grams
Posted: 18 Jul 2021, 19:55
by TonyL
3mm copper tube annealed and shaped using 2 mm brake cable
Posted: 18 Jul 2021, 19:56
by TonyL
canopy tubes soldered together
Posted: 18 Jul 2021, 19:59
by TonyL
used aluminium foil to act as heat sinks
canopy placed on fuzz
Posted: 18 Jul 2021, 20:01
by TonyL
wings and v-tail assembled/aligned
Posted: 18 Jul 2021, 20:04
by TonyL
Posted: 18 Jul 2021, 20:05
by TonyL
battery to be fixed with scratch tape
Posted: 19 Jul 2021, 14:34
by TonyL
V_TAIL DAMAGE REPORT:
During the v-tail assemby the 2 mm balsa - 2mm steel wire interface proved fragile! It is strongly
recommended to epoxy a .4 mm ply panel over the entire width of the last 5 cm's!
The picture shows the original setup that should be reinforced!
Posted: 30 Jul 2021, 16:24
by TonyL
landing skid from 2 x 3 mm plywood
Posted: 30 Jul 2021, 16:25
by TonyL
tapered to 1 mm thickness and 1mm dural insert at front
Posted: 30 Jul 2021, 16:26
by TonyL
tapered skid thickness at rear end
Posted: 30 Jul 2021, 16:27
by TonyL
two skid parts epoxied together and cleaned up
Posted: 30 Jul 2021, 16:28
by TonyL
M 5 brass insert made from M 5 screw with M3 allen bolt
Posted: 30 Jul 2021, 16:29
by TonyL
M 5 brass insert epoxied into hardwood block
by TonyL
dural strop bolted to ply-balsa ply sandwich of 15 mm thickness
- fb34s.JPG (13.09 KiB) Viewed 1318 times
Posted: 30 Jul 2021, 16:30
by TonyL
front of skip bolted to fuzz
Posted: 30 Jul 2021, 16:31
by TonyL
rear of skip in dural strop
Posted: 30 Jul 2021, 16:32
by TonyL
3 mm ply reinforcements between formers 4 & 5, 4 mm balsa reinforcement aft former 5
Posted: 08 Aug 2021, 14:39
by TonyL
Finished building the other wing, cut a little jig to sand the leading edge, the ribs look
very simplar to the original Ka 3 profile: Göttingen 549, 14% maximum thickness and a
leading edge defined by only a few points
Posted: 08 Aug 2021, 14:41
by TonyL
Both wings covered in DIACOV
Posted: 08 Aug 2021, 14:43
by TonyL
3 mm ply reinforcements behind former 5
Posted: 08 Aug 2021, 14:46
by TonyL
Major modification of the rubber skid support, using a squash ball,
squash ball cradle from 3 mm ply to support landing skip
Posted: 08 Aug 2021, 14:47
by TonyL
cradle with squash ball to support landing skip
Posted: 08 Aug 2021, 14:52
by TonyL
first rough balancing with the V-tail indicates 500 grams of lead in the nose
(not including the battery) when the fuzz is covered and painted I will fine-tune
the balance
the nose is build-up from balsa and 500 grams of lead glued to the formers, top, side, bottom and front views
Posted: 14 Aug 2021, 16:46
by TonyL
Posted: 14 Aug 2021, 16:47
by TonyL
Posted: 14 Aug 2021, 16:48
by TonyL
canopy frame from 3mm and 2 mm annealed copper tube,
using alu-foil as heat radiators to keep everything together
Posted: 14 Aug 2021, 16:54
by TonyL
Help request for canopy glassing:
using polyzap on 0.5 mm rhodoid (hope this is English) caused
a brittle bond and brittle cracks in the rhodoid.
using epoxy glue avoided the brittleness but the joint with the
rhodoid was weak at best (used alcohol to clean and 300 grit
sandpaper to coarsen the rhodoid for the glue joint.
ps: used the polyzap on some other thin plastic transparent
material, glue joint was good, but the plastic became very
brittle aswell!
any suggestions are very welcome!
Posted: 14 Aug 2021, 16:55
by TonyL
skid and squash ball damper installed
Posted: 14 Aug 2021, 16:56
by TonyL
skid covered (not sure it will last as there are some rocky parts on our flying hill)
Posted: 14 Aug 2021, 16:58
by TonyL
Posted: 14 Aug 2021, 16:59
by TonyL
fuzz covered, fuzz and wings ready for painting
Posted: 14 Aug 2021, 17:08
by TonyL
I found it very difficult to clip on the ball-joints for the v-tail control, after
the v-tail is installed on the fuzz
Thus I clip on the ball joint with the v-tail on the table, and then slide
the carbon rods into the fuzz, tilting the v-tail by 90 degrees makes it easy
the carbon rods will snag on the formers close to former 5, but with a thin
stick from the nose end this can be helped. With a little practice this takes less than 1 minute. Then the v-tail is positioned and the two 2 mm screws tightened.
I then adjusted the length of the carbon tube using the screw-on joint.
