This has proved itself to be a very practically-sized model & a smooth performer. As far as I know, there are no IV's in this particular configuration, although there seems to be a variety of Bergfalke 3's thus modified. The unusual scale is due to the 1/4 scale version being scaled down to a size that suits existing stock material dimensions. The last minute decision to hide a motor in the fuselage has proved well-founded, as last weeks inaugural slope flights demonstrated in the light conditions...
Construction starts on the jig: note that the longerons are cut longitudinally at the front to ease the curvatures...
Re: BERGFALKE IV CABRIO 1:4.7 SCALE
Posted: 06 Jun 2021, 11:48
Once all the longerons are in place, the tail mount can be added, and then a template made up for the top sheeting...
Posted: 07 Jun 2021, 10:53
Once the front planking & the top deck are in place, the fuselage can be removed from the jig. Note that there is a slight compound curve at the front of the top decking, hence all the masking tape. An alternative would be to separate the panel at F8...
Posted: 08 Jun 2021, 11:56
To allow for the tapering thickness, the tailplane is built inverted on the board, than sheeted on top. Then it's inverted once again, with jigging supports spot-cyano'ed to the top sheeting, placed back on the board, and the bottom sheeting added...
Posted: 09 Jun 2021, 10:57
The making of the 'cab'...
Posted: 10 Jun 2021, 10:17
With some 5mm sq balsa added to increase the glueing area, the ply side panels are added, followed by the top panels...
Posted: 11 Jun 2021, 11:04
Now, the ply sheeting can be finalised at the front...
Posted: 12 Jun 2021, 11:08
Now the wheel mount can be finalised...
Posted: 13 Jun 2021, 10:13
Now for the elevator: the first job is to hinge up the false LE to the tailplane and sand it flush. It can then be removed, and the elevator built over the plan. Then the final LE is added and rounded off...
Posted: 14 Jun 2021, 11:03
Details of the elevator actuating pushrod arrangement...Now, construction of the fin/rudder starts.
Posted: 15 Jun 2021, 11:04
Followed by the rudder: once again, the false LE is hinged up before construction commences...
Posted: 16 Jun 2021, 11:05
Now the tailwheel assembly can be added, prior to ply-sheeting the rear of the fuselage...
Posted: 17 Jun 2021, 10:10
Moving on now to the wings...using my current wing-build practice, the lower main spar is built over the plan. Once the upper spar is added, the ply webs are glued to the front of the spar and the sub-spar dropped in in front of them.
Posted: 18 Jun 2021, 10:14
The second wing joiner sits between the sub spars: when fitting two joiner boxes like this, it's always prudent to insert the blades into the boxes to ensure that they are exactly parallel as the epoxy cures...
Posted: 19 Jun 2021, 10:05
Once the lower sheeting has been added (not forgetting the ply plate to accept the rubber band retention hook) the wing can be placed on its jigging supports, weighed down and the top sheeting added...
Posted: 20 Jun 2021, 10:06
Now the wing root can be finalised and lined with 0.8mm ply...
Posted: 21 Jun 2021, 11:10
The wing root fairing on the fuselage is simply a 1.5mm ply profile: this is best made by offering up to the wing root and marking around. Also, it's best to leave the wing joiner boxes and incidence tube proud of the wing root up to this stage. This way, a ply blank can be pushed into the wing root with two layers of masking tape in the appropriate places. The resultant marks in the tape will show where to cut and drill, then, when you mark out the profile it will be accurate in relation to the protruding brass...
Once fitted, it was time to add the 6mm half-round dowel from my nearly diminished stock to simulate the metal tube of the full size. Then, at this stage, it was time for the obligatory test rig!
Posted: 21 Jun 2021, 15:44
by Jus Gordon
Hi Chris,
Another great build thread, will you be flying this at Whitesheet this weekend, weather permitting?
Posted: 21 Jun 2021, 16:56
Of all the sad words of tongue & pen...'weather permitting' are the saddest...
Posted: 21 Jun 2021, 17:12
Not looking good at present...
Posted: 21 Jun 2021, 19:12
Depends which weather forecast you look at
Posted: 22 Jun 2021, 11:09
It's often best to make up the combined brass boxes for the fuselage with the wings joined together as the epoxy cures. The boxes extend into the wing root fairing and are trimmed off at the end of the process...
Posted: 23 Jun 2021, 11:57
The ailerons are fairly simple: just built over the plan. Then it's time to fettle the winglets. (These at least are scale, as there is one Bergfalke 4 on the 'net fitted with them)
Posted: 24 Jun 2021, 09:54
Now for my favourite bit: the airbrakes...
Posted: 26 Jun 2021, 11:48
Continuing with the airbrake saga...
Posted: 28 Jun 2021, 19:56
That's the airframe pretty much complete...
Posted: 29 Jun 2021, 11:21
In a last-minute decision I decided to fit the spare Turnigy G32 that I had lying about. (A wise move as it later turned out)
Posted: 29 Jun 2021, 12:00
And it was all going so well!!
Posted: 30 Jun 2021, 09:53
I've used my usual finishing method: Solartex and 2k paint on the fuselage, and HK film on the flying surfaces...
Posted: 30 Jun 2021, 12:23
Nice Chris.
Posted: 30 Jun 2021, 19:30
by SedB
Your Bergfalke looks stunning! That thin chatline does it all!
Daniel
Posted: 30 Jun 2021, 21:30
by Jus Gordon
Very nice, great job!
Posted: 01 Jul 2021, 11:28
And the coop de grass...le video
Posted: 01 Jul 2021, 11:34
You made a nice job of Cooping de grass...
Posted: 01 Jul 2021, 13:17
by Max Wright
That's what it's all about.
Trez beanie.
Re: BERGFALKE IV CABRIO 1:4.7 SCALE**
Posted: 04 Sep 2021, 10:59
by ddlawrence
nice! that is really something.
Posted: 04 Sep 2021, 11:47
by Alex Tankink
Thatโs a lovely ship. The Cabrio is so unique. Great choice for a project and inspiring
