MartinE
Post
by MartinE »
Youth
Cut down the wing joiner to length and sanded down to required thickness, then put another coat of resin on.
MartinE
Post
by MartinE »
The fuselage sheeting hasn't given me the nice shape I want, so having to fill (and will then sand down to a nice smooth finish).
This filler is really light/fine and sands easily.
With hindsight, some intermediate formers & stringers would have helped.
NSWanderer
Post
by NSWanderer »
Hi Martin,
Interesting how the distances between the formers and stringers look quite reasonable on your plan - I'm surprised.
MartinE
Post
by MartinE »
I sanded down the filler and the shape is much smoother, still some areas to be reshaped but will do those when the top has been glassed.
Before I do that, the wings roots need to be lined up & bonded in - i used the wing-joiner & the location pins to make sure it all aligned.
MartinE
Post
by MartinE »
The tailfin gets a bias skin of 25gsm glass on each side, before cutting & fitting to the fuselage.
To keep it light, I absorbed excess resin with a paper towel.
MartinE
Post
by MartinE »
As mentioned before, the elevator will have a live hinge - the Kevlar is 60gsm on the bias (I rolled the fabric to flatten it as much as possible).
Spray with adhesive & allow to cure before cutting the strip.
A 12mm wood chisel is used to make a depression in the foam, ready to accept the Kevlar, fixed in with 3m 75.
The spar cap is made up of multiple lengths of 80gsm uni-carbon, folded lengthways. Inserted into wing depression.
NSWanderer
Post
by NSWanderer »
Your progress is impressive - should be flying by the first weekend of 2022!
MartinE
Post
by MartinE »
Still lot's to do, but it's certainly taking shape nicely.
MartinE
Post
by MartinE »
Cut the rudder off the tailfin and trimmed for a trial fit to the fuselage.
Seems to line up nicely, vertically & lengthwise.
MartinE
Post
by MartinE »
Added the balsa sheeting above the wing roots and then glassed the top surfaces (100gsm bias).
