Lasercut sailplanes/Jilles Smite 1/3 scale ASK18
Rich vale
Post by Rich vale »
You must all forgive me but I have lost the initial photos of the fuselage construction. I will pick the build up at the point of the fuselage sheeting. And Yes I am building Two. The stringer and formers were constructed over the wooden pieces extending from the side of my bench. All alignment was done with a drawn centreline on these wooden fingers. Both fuselages were at the glue drying stage at about 4 hours assembly of each.
Rich vale
Re: Lasercut sailplanes/Jilles Smite 1/3 scale ASK18
Post by Rich vale »
All 0.8mm sheeting added to basic fuselage structures. I decided to use CW`s method of planking the top nose sections. I`ve yet to add car filler to the ply but it does look promising so far.
Two fuselages at once...my hero!
Rich vale
Post by Rich vale »
Started the tail plane and fin with rudder.
Alan Alderwick
Post by Alan Alderwick »
That looks like it is going together very nicely. Cracking build, like the way you are clamping and jigging to keep everything straight and true.
Rich vale
Post by Rich vale »
Finished of rudders and elevators skinning only LE to complete. First fit of fins over tail planes.
Fitting to fuse
Fitting to fuse
Rudders and elevators framing completed. Ready for LE
tail plane seat added
Mike Forsyth
Post by Mike Forsyth »
I'm keeping a close eye on this build as it's one of my favourite gliders.
Rich vale
Post by Rich vale »
I decided to bite the bullet and fit the canopies this weekend after reinforcing the wing tube center and forming the tail plane seat.
Chop strand reinforcing to wing tube
Tail plane seat from filler
The very large canopy
Rich vale
Post by Rich vale »
First of the two. I always trim a little at a time until a reasonable fit is achieved. The glue and when dry a final sand.
Sides marked for trimming
front and rear cut to fit
Canopy frame clamped in place
Finished fit
Finished fit
Rich vale
Post by Rich vale »
Started to assemble tow releases and nose out lines.
Ready for lead and filler
Cliff`s commercial release and tube
My pin and loop release
Both fuselages ready for lead and filler
