Ka6E build**
Jilles
Re: Ka6E built
Post by Jilles »
Some answers on the previous posts
Glassing a compound curved fuselage is no problem if you use a low density glass fabric. For this type of job I use 18gr/m2
Using a roller as shown on previous pictures makes the job very easy. Just lay the glass on the fuse dry and spread by hand over the fuse
Then roll in the resin. Do not apply to much resin. If a glass job is done properly you will just see the weave of the fabric and that will be filled by the primer filler. The rollers are the cheapest one can get because cleaning is not economic.
For painting I use spray cans of Automotive paint. I do not have spray gear that you have to clean for half a day after use. Two packs are expensive.
With ready available spray cans you have a big choice of colors. Also I can get at the automotive outlet where I buy the cans have colors custom made in spray cans (at a price) I use an automotive filler/primer spray first and sand that as smooth as possible before applying the final coat(s)
Jus Gordon
Re: Ka6E built
Post by Jus Gordon »
Jilles,
Thanks for your answers.. Always appreciate tips from the pro's!
Jus
Jilles
Re: Ka6E built
Post by Jilles »
I have one spare canopy here in Brisbane and I am told the new Zealand source will do an other run to get spares for would be builders in our region
Australia post is very heavy handed in the fees to make sending canopies to Europe economical. the other way around is half the cost I hear. As Cliff mentioned they are available in the UK
Jilles
Jilles
Re: Ka6E build
Post by Jilles »
After lots of sanding finally dared to do the paint job.
The fuse is done now including tailbits and canopy.
A member friend in my model club has a NC cutter for stick-on logo's. I used the Alexander Schleicher Logo and included the KA6E model type in the design
next project, painting the wings
Jilles
Re: Ka6E build
Post by Jilles »
Got it all completed today. only need to do the balancing act. At the moment it weighs in at 7.7 kg. I hope not to exceed the 8kg mark.
At scale 1:3 it should be fine
The COG is not far from what it should be so there is hope.
Re: Ka6E build
That is nice.
Re: Ka6E build
Very nice indeed Jilles.
Well done.
Re: Ka6E build
That looks splendid Jilles. Yet another model to add to my build list.
Jilles
Re: Ka6E build
Post by Jilles »
Got finally to balance the Ka6E. During the built the nose in front of former F1 was already 90% solid lead
Only required 200 gr lead to get the C.O.G at 100mm from the LE. It may be a bit forward but this I always do for a maiden
The C.O.G was located by means of the graphical way as suggested in the Book of model Aerodynamic of Martin Simons
For those that are building the Ka6E of my plans a breakdown of the weight is included
The target of maximum 8kg flying weight was met.
KA6E-WEIGHT-FINAL.pdf
(16.56 KiB) Downloaded 281 times
COG-LAYOUT.pdf
(15.97 KiB) Downloaded 286 times
Noël Rumers
Re: Ka6E build
Post by Noël Rumers »
Looks great!!!
Noël
