Plan ordered from Triplet Publications, building this 1/5 scale electric glider from Chris Williams plans.
Geoff
BJ-1 Duster**
Re: BJ-1 Duster**
Still waiting for the plan to arrive from Traplet Publications, hopefully after the easter break, I have also downloaded and printed the 1/4 scale plan of the Duster that's available here on Scale Soaring UK, also thinking of building this 1/4 scale electric version.
With Chris Williams 1/5 scale version can see the the following is suggested 2810 1100kv brushless motor, a 60 Amp ESC Speed Controller with also a 3S 2200 LiPo, what motor, ESC and battery would you place in the 1/4 scale version, guessing the weight would be between 5 - 6 lbs.
Geoff
Geoff
Re: BJ-1 Duster**
Cliff,
I will wait for Chris Williams plan to arrive and study the plan and see if it's worth the time and effort to up to 1/4 scale, if not will plan to build at 1/5 scale, I downloaded Jim Ealy plan here on Scale Soaring UK.
http://www.scalesoaring.co.uk/VINTAGE/D ... odels.html
Re: BJ-1 Duster**
Plans have finally arrived, also first attempt at uploading some images.
