BJ-1 DUSTER**
BJ-1 DUSTER**
A short thread for the 5th scale version of my Duster plan...
Re: BJ-1 DUSTER
Chris,
Thank you for putting these photos on here, will keep my build thread up to date.
Geoff
Geoff
Re: BJ-1 DUSTER
Here are all the parts...as usual, check the print-out against the plan...
- Attachments
- C2.pdf
- (233.61 KiB) Downloaded 291 times
- F1-4.pdf
- (251.46 KiB) Downloaded 222 times
- F5 H1.pdf
- (241.35 KiB) Downloaded 207 times
- F6 H2.pdf
- (236.81 KiB) Downloaded 215 times
- F7-10.pdf
- (236.63 KiB) Downloaded 200 times
- FIN-RUDDER.pdf
- (249.3 KiB) Downloaded 242 times
- FRONT FAIRING TEMPLATE.pdf
- (238.39 KiB) Downloaded 209 times
- H3.pdf
- (227.76 KiB) Downloaded 187 times
- H4 H5.pdf
- (222.4 KiB) Downloaded 190 times
- MISC 2.pdf
- (242.11 KiB) Downloaded 199 times
- MISC.pdf
- (262.52 KiB) Downloaded 197 times
- R1.pdf
- (314.13 KiB) Downloaded 189 times
- R1-12.pdf
- (294.27 KiB) Downloaded 193 times
- R2-12.pdf
- (254.12 KiB) Downloaded 194 times
- REAR FAIRING TEMPLATE.pdf
- (249.53 KiB) Downloaded 200 times
- WING JIG SUPPORTS ETC.pdf
- (264.78 KiB) Downloaded 225 times
Re: BJ-1 DUSTER
Continuing...
Re: BJ-1 DUSTER
Finishing off the tail and starting on the wings...
Re: BJ-1 DUSTER
The top sheeting will be added after the wing centre section is laid on to the wing support jigs
Re: BJ-1 DUSTER
Now for the outer wing panels...
Re: BJ-1 DUSTER
Sorting the TE brakes and wing tip... I made up the up-turned tips of the full-size, but in comparison to Smallpiece's conventional tips, there seems to be a slight reduction in beneficial stall characteristics, so one up to the Wookie
