Page 11 of 14
Re: Teakle ASW 20 3.5/1
Posted: 11 Nov 2016, 15:17
Barry,
I didn't say no flying over the winter, merely that my '20 would go towards the rear of the forest of fuselages stored at the back of my workshop.
Anyway, I don't live quite as far south as you :) :)
Posted: 12 Dec 2016, 12:42
by Martin Church
I'm planning on putting micro rudder & elevator servos as near as I can get to the control surfaces. What would be a good mid priced servo for each control how many kg's are needed? I'm thinking over 2kg torque but less than 5kg at 4.8v
Posted: 12 Dec 2016, 15:31
by Chris Bowles
Hi Martin, I have used MKS 135, or if you need a bit more power MKS 125, it's always better to have to much than not enough !!
Chris
Posted: 12 Dec 2016, 16:55
by Martin Church
Did you mean KST 125 KST 135 Chris?
I searched mks 125/135 but came up with nothing on HyperFlight
Guessing that around 5.2kg is fine on elevator & go fo the 125 @ 7.0kg for rudder
http://www.hyperflight.co.uk/products.a ... g-7-0kg-cm
http://www.hyperflight.co.uk/products.a ... g-5-2kg-cm
Posted: 12 Dec 2016, 17:10
by Chris Bowles
Martin,
Yes got it wrong again, I meant KST, have been using them for a while now, got 20 plus, no problems yet, thats the kiss of death!!
Posted: 12 Dec 2016, 18:38
by Martin Church
Cheers Chris not badly priced either so I'll get one of each ordered up :)
Posted: 20 Apr 2017, 14:50
by Andrew Wallace
I'm just about to start building one and there's a few questions I would like to ask
What's the best way to do the elevator, do you go with the long bar in the fin or do you mount a servo in the tail or the fin ?
Where do you fit the servo for the airbrakes?
Thanks
Andrew
Posted: 20 Apr 2017, 16:15
Andrew,
I buried my elevator servo in the tailplane, with a short drive to the elevator.
Much more rigid, and simpler to rig as long as you don't let the fuselage connector drop back down the fin ;)
No problems in flight over several years use.
Posted: 20 Apr 2017, 16:28
by Martin Church
Peter Balcombe wrote:Andrew,
Hi Pete I've been slacking after having big issues after carving the ailerons from the living hinge as advised.
It's now impossible to tape hinge & get enough movement for the ailerons dye to warpage after being detached. Not sure what to do next really only thing I can think of is to put plastic pin hinges to control the gap to a size that will allow them to waggle the required amount.
What type of servo did you fit & what pull does it give you at 4.8v
Martin
Posted: 20 Apr 2017, 16:45
by Andrew Wallace
Peter when joining the tailplane halves did you strengthen it in any way
Thanks
