Frsky Hours X10
Moderator: VinceC
Paul Joslyn
Frsky Hours X10
Post by Paul Joslyn »
Hi all, anyone got any hands on experience of this tx. Thinking of upgrading from my X9D.
Regards
Paul
Paul Joslyn
Re: Frsky Hours X10
Thanks. I also have a X9E (tray version of the X9D) but it's so big it's a pain on the hill, hence I went back to the 9D. The X10 is just a little larger than the 9D, so thinking that would be better.
Just about every review I found so far I'd from a drone pilot, so want to here from a proper flyer :)
Re: Frsky Hours X10
B****r, I was going to say that...
Paul Joslyn
Re: Frsky Hours X10
Hi Clive,
The Horus X10 arrived yesterday. Very nice!
Have you flashed yours to Open TX?
I was planning to but having read a few warnings that if you do it wrong you can turn it into an expensive paper weight, i'm a bit nervous now...
Regards
Paul
Re: Frsky Hours X10
Or you can e-mail me on modelgliding (at) aol.com
Paul Joslyn
Re: Frsky Hours X10
I made a long list of pro’s and con’s at the weekend and decided that the risk of turning it into a paper weight was not worth it and i should leave it on FROS.
But it was like an itch I was trying not to scratch….
So after reading the procedure twice and following it REALLY carefully, I though sod it and its OK – it’s now on Open TX 
So now have to re-program the 3 models I had already set up on it…. 
Re: Frsky Hours X10
Great stuff Paul, well done.
I read through that paper again, and it seemed that most of the scary stuff was to do with going back to FrOS.
Welcome to the wonderful world of Open TX.
:D :D :D :D
Paul Joslyn
Re: Frsky Hours X10
I'm hoping that most of the models from my X9D will transfer via Open TX companion. Then it will just be a simple case of checking and tweaking...
We'll see..
Re: Frsky Hours X10
Seems to work in companion OK, good luck.
mick a
Re: Frsky Hours X10
Post by mick a »
still looking at the frisk system , the 10 sees good, gone of the 9xe seems to big
what is the open tx in simple terms ? , just not getting it at the moment
mick
