should i update
Moderator: VinceC
mick a
should i update
Post by mick a »
hi
i have updated to 2.3.2 , should i update to the 2.3.5 or just leave it , any advantages or disadvantages either way ?
Re: should i update
Entirely your decision Mick.. I always wait a week or so after an update is released, then install.
Andrew Ray
Re: should i update
Post by Andrew Ray »
I don't update unless there is some benefit to me i.e. some additional function that I might use, otherwise I leave well alone.
mick a
Re: should i update
Post by mick a »
thanks gents
as i said uploaded the .2, not sure if it’s an effect but i can’t seem to get the images to the model in model menu, they are on the images folder on transmitter but won’t transfer
will try to delete and try again, not an issue, just niggly
mick
