Laser cutting
Re: Laser cutting
That sounds fair enough to me Cliff as it should to everyone else. Its a bit like a customer expecting me to correct a mistake in a bathroom refit done by someone else....I would politely suggest they go back to the original installer unless they agreed a fee with me upfront.
- B Sharp
Re: Laser cutting
Sounds absolutely right to me Pat (and Cliff). The first point of recourse always has to be the supplier. However if they tell you to "sling your hook" then you can only expect someone else picking up the pieces to charge you through the nose (and quite rightly so).
If you don't get good service or you get shoddy goods then let us all know about it in the "Bad Service" thread so that we can all beware that trader in the future.
Re: Laser cutting
So right Cliff, and Pat.
Reputations are built on good service and TRUST, both ways.
G
G
Re: Laser cutting
Geoff Pearce wrote: ↑03 Oct 2018, 18:58So right Cliff, and Pat.
It also helps to use good quality materials that won't let you down
G
