Laser cutting
Members offering their services to modellers.
Laser cutting
Post by Cliff Evans » 22 Mar 2015, 22:29
Laser cutting for most things modelling available.
www.lasercutsailplanes.co.uk or just PM me.
Re: Laser cutting
Post by Cliff Evans » 13 Jul 2015, 16:59
For the umteenth time, today I have been asked yet again to put right a kit cut from a plan on the forum that has been cut by some body else, ( I will not name names, so please do not ask). Up to now I have helped, but there comes a time when enough is enough. From now on I can only support kits cut by me. For those of you that have used me, you know I will give all the support that I can, normally over and above!
Pat Marsden
Re: Laser cutting
Post by Pat Marsden » 14 Jul 2015, 05:56
That sounds fair enough to me Cliff as it should to everyone else. Its a bit like a customer expecting me to correct a mistake in a bathroom refit done by someone else....I would politely suggest they go back to the original installer unless they agreed a fee with me upfront.
Re: Laser cutting
Post by Cliff Evans » 14 Jul 2015, 08:49
Thanks pat, hope all is well with you.
Re: Laser cutting
Post by B Sharp » 14 Jul 2015, 19:51
Sounds absolutely right to me Pat (and Cliff). The first point of recourse always has to be the supplier. However if they tell you to "sling your hook" then you can only expect someone else picking up the pieces to charge you through the nose (and quite rightly so).
If you don't get good service or you get shoddy goods then let us all know about it in the "Bad Service" thread so that we can all beware that trader in the future.
Brian. :!: :!: :!:
Geoff Pearce
Re: Laser cutting
Post by Geoff Pearce » 03 Oct 2018, 18:58
So right Cliff, and Pat.
Reputations are built on good service and TRUST, both ways.
G
Geoff Pearce
Re: Laser cutting
Post by Geoff Pearce » 03 Oct 2018, 19:01
Geoff Pearce wrote:
03 Oct 2018, 18:58
It also helps to use good quality materials that won't let you down
G
