1/2 scale Lo100
alexis scott
Re: 1/2 scale Lo100
Post by alexis scott »
Quick progress shot with my girls today, hopefully I can get serious with paint over the weekend
alexis scott
Re: 1/2 scale Lo100
The final pre aint jobs continue, last night I started running all the wiring through and did the final set up of elevaor drives, I've made brass tube inserts for the connection between the pushrods end and elevator horns so now when I assemble the tail I can drop the new brass tube horn ends into the aluminialuminium pushrod ends and secure with a screw through both, I also rebuilt the rudder drive with a double ball on the idler bellcrank which has removed all slop and improved the geometry of that somewhat, the rear of the fuselage is now all programmed and working I have had the wings all working but will be doing another final hook up and test of flaps and ailerons before paint now that the hinging is all permanently attached, I've settled on ,in the cavity under the wing as the perfect spot for the receiver so the extension leads all are set up to go up to there including doubled up power wiring from the Front mounted battery tray.
john greenfield
Re: 1/2 scale Lo100
Post by john greenfield »
Looks like you are getting close to the finish line Alexis, nearly ready to test fly.......Do I need to book an airline ticket to come over to Oz ???!
alexis scott
Re: 1/2 scale Lo100
Always good to see you down under John, I'm hoping it will be ready for the SSL Milang aerotow at the end of may, it's very close to flyable now so should make it
alexis scott
Re: 1/2 scale Lo100
Started paint now, wings and fuselage are white now and rudder and tailplane have their blue, started masking nose scallop this morning , will possibly get the blue on fuselage tonight think this wing picture is only after first coat colour looking pretty solid now
john greenfield
Re: 1/2 scale Lo100
Looking good Alexis.
Have you any idea of the final weight yet ?
alexis scott
Re: 1/2 scale Lo100
Under 23kg is looking like the current estimation based on prepaint weights
alexis scott
Re: 1/2 scale Lo100
Pre work progress this morning
Geoff Pearce
Re: 1/2 scale Lo100
Post by Geoff Pearce »
Looking really nice, paint job 1st class.
Look forward to seeing it at an event
Geoff
alexis scott
Re: 1/2 scale Lo100
Geoff Pearce wrote:
03 May 2018, 20:30
Geoff
Thanks Geoff hoping I can get to some events now too
