Cockpit Instruments
- VinceC
- Site Admin
Cockpit Instruments
If you are stuck for instruments, you can make up your own panel from these instruments attached which I have drawn over the last few years. If you want the bezels, Cliff will be able to help or even 3D print the full panel for you complete with the faces
- Attachments
- Instruments-1.pdf
- (2.62 MiB) Downloaded 355 times
- Instruments-2.pdf
- (3.3 MiB) Downloaded 310 times
- Instruments-3.pdf
- (528.71 KiB) Downloaded 303 times
Re: Cockpit Instruments
thanks vince this is very helpful is it pos to move this post to modeling tips so it will not get lost ROO
- Cliff Evans
Thanks Vince, these should prove very usefull to most members.
some more.
- Martynk
Brilliant. Just what I have been looking for.
Very many thanks!
Very many thanks!
