Hi Chaps
There is a strong possibility of me committing model covering in the next few weeks. If anyone has any great tips on applying natural Solartex, then please let me know. I'd rather learn from your mistakes than make my own - again.
Cheers, Mike
Applying Solartex
Re: Applying Solartex
It's hard to make a mistake with Natural Solartex...
Mike,
I would advise first applying a covering adhesive such Balsaloc (or similar) over a wooden structure before applying the Solartex as this makes it stick much better.
Use the general covering instructions given with the rolls.
I would also suggest that unless you are intending to paint the Solartex, you paint the surface of the covered model with dope or similar to seal the Solartex weave. Otherwise the surface will quickly become grubby and is difficult to clean.
I've never needed to use Balsaloc, other than for the under cambered sections of the wing ribs. Once properly tautened, Solartex stays stable for years... My limited experience with pre-painted Solartex was not nearly as good...!
Read and follow the instructions supplied with Solartex to the letter...and don't use a heat gun.
