PMP / PhoenixMP - Enigma CG?
All non-scale topis should go in here for discussion.
mjcp
Post by mjcp »
Good evening,
Has anyone got the recommended CG for a PMP Phoenix ?
Thanks,
Marc
m̶j̶c̶p̶ Marc
Hanger -
Graupner (old) K-8b, Mini Solius chuck glider conversion, UMX ASK-21, HF/Czech 2m ASW27, DG808s 4m, X-models Mini-blade, Lidl glider pitcheron.
Martin G
Re: PMP / PhoenixMP - Enigma CG?
Post by Martin G »
Marc,
Give Stan Yeo a call on 01626332287.
He is the owner of Phoenix Model Products.
Martin.
Martin G
Post by Martin G »
Marc,
Any luck with the CG?
A review of this model on Mike Shellim’s RC-Soar website says that the CoG is set at 80mm, so presumably that means 80mm behind the root LE.
Google ‘Review: Enigma 60" EPP Pylon Racer’
mjcp
Post by mjcp »
In the end, I winged it and went for what “felt right”/ “looked right”... erring slightly nose heavy.
Flew it on Sunday at white sheet - no issues whatsoever!
Marc
m̶j̶c̶p̶ Marc
Hanger -
