Multiman glider
Robcrad
Multiman glider
Post by Robcrad »
Hi,
I am building an old glider called "multiman" designed by Rodger Pullen. Has anbody else build and flown one?
I have modinised the plan and replaced the mechanical flapperon mixing with separate servos and was interested in any information from other builders.
Rob
Radley Clarke
Re: Multiman glider
Post by Radley Clarke »
Hi Rob
built one for my son about 2 years ago shortened the span a bit (at his request) and also used 2 servos per wing.
He has not flown it yet (crazily busy diesel engineer)
Was a nice build used foam wings.
Also have plans for Roger's Medicine Man which now I am retired is on my to do list.
Cheers stay well
Radley
Robcrad
Re: Multiman glider
Post by Robcrad »
Hi Radley,
Thanks for the reply, Be interested to hear how the maiden flight turns out, I am a little concerned that the weight of mine is high, it weighs in at 2.3kg, how heavy was yours?
Stay safe
Rob
