Page 2 of 2
Re: Pat teakle vega fes mod
Posted: 01 Jul 2020, 13:31
by terry white
Hi Brian, Do not worry about side thrust, the power to wing span drag will not give you an issue. About 2-2.5 degrees of down thrust should allow on/off switching of the motor without too much trim change to the elevator,The final bit of trim change can be achieved with the elevator mixing control in the transmitter. Hope that helps.
I have noticed that very few members are visiting the new Video section set up by Cliff for YouTube vids so I have put the link here as it is appropriate to sustained glider flight.No matter what the purist may think even jet gliding is here in the full size now and so making the model gliders with jets attached true scale. Not sure I like this one,but hey every one to their own. Terry.
Posted: 02 Jul 2020, 07:20
by Brian Taylor
Many thanks Terry, down thrust only it is.
Brian
