Hacker motor choice
Elliot Howells
Hacker motor choice
Post by Elliot Howells »
Guys and gals,
I'm struggling to get the Hacker motor people to understand my needs, I realise I don't speak German, so that much is my fault...
My Ash works amazingly well on a 14x10, but I'd like to go smaller with the same power output, like 12.5 or 13".
Does anyone know of a motor that might meet this requirement, there's a turbine EDF motor on the Hacker pages that looks like it might:
https://www.hacker-motor-shop.com/Brush ... 8623&p=293
I need to know so I can order the torcman stuff with the right shaft sizes.
Cheers, Ell.
Jez_B
Re: Hacker motor choice
Post by Jez_B »
Hi Ell
That's a mighty powerful motor you show in the link. It recommends 8S and has quite a high RPM/v for its size.
So much depends on the model size /weight you want to strap it to. Maybe you can provide that
Elliot Howells
Hi Jez!
as an example, the ASH, at 1/3 scale is about 12Kg and 2000w on the 14x10, looking for something with higher Kv that will give me the same power.
I thought an EDF motor might be okay if I could find one with low enough Kv...
The ASH performs really well on the 14x10, it's just prone to catching.
Ell
SP250
Post by SP250 »
Elliot
There is now an excellent calculator / set up finder on the Hacker website you can use FOC here:-
https://www.ecalc.ch/setupfinder.php?ha ... vation=300
Hope that helps
John M
Eliot,
What is the Kv of the motor that you are using, and how many cells??
Elliot Howells
Barry, it's this one, on 8S
https://www.hacker-motor-shop.com/Brush ... 735&p=7382
John, thanks, that's very useful.
Ell.
Elliot Howells
Thanks to the Hacker motor calc, I've just found these motors which look promising. Also very reasonably priced.
https://www.tfl-hobby.de/Motore--Halter ... ---9D.html
*edit* but for boats... bah.
