Control surface gap tape WANTED
Place your Wanted adverts here.
George Gosbee
Post by George Gosbee »
WANTED the control surface gap covering tape. IE clear tape that is only adhesive on part of its with, to go over the gap of a top hinged control surface.
George.
07836581247
mick a
Re: Control surface gap tape WANTED
Post by mick a »
never seen that type
what i do is slice 1 piece of tape to the width you don’t want sticking
and stick that to the tape sticky to sticky side, that way you have two sticking surfaces for
trailing edge and control surface
i use blenderm tape
hope that makes sense
mick
Keith
Post by Keith »
Diamond tape I've used this for years gooD stuff.
Keith
Elliot Howells
Post by Elliot Howells »
It's horrendously expensive, you can get it from lindinger
https://www.lindinger.at/en/airplanes/a ... 5lfm-clear
Plan hanging tape is very much the same if you can find it.
https://plan-tidy.com/products/a0-film- ... 7251598391
Ell.
terry white
Post by terry white »
George, Thin mylar strip fixed with double sided tape to the wing a little way back from the control gap to allow it to take on a slow bend on a down going aileron/flap. is the way to go.
I have a little to spare if you would like. Send me you're address and length requirement on PM and I will send it on return.
Regards Terry.
jimbo
Post by jimbo »
I heard you can use the stuff off the full size gliders, no idea where to get it from though.
Antonia
Post by Antonia »
Morning, here you go I've brought curved mylar tapes from them, no issues
https://www.gromotec.de/shop/?cat=c2_Sp ... ender.html
Hope it helps. Antonia
Simon WS
Post by Simon WS »
Rather less expensive at Ripmax! £7 for 5m (caveat is I've never used it so don't know if it is any good!)
http://www.ripmax.com/Item.aspx?ItemID= ... ry=130-030
Simon
Phill Tadman
Post by Phill Tadman »
